I have recently tried to export a code to a MIC, and obtained the seg fault error. I did some research, and believed it was because my arrays were not aligned properly. I currently have a code whose premise, IE an example since the real one is too long,is as shown below.My goal here is to always have the cl, loc_r, and cv variables aligned on 64 byte boundaries for use on a xeon phi coprocessor. However, I don't know how to get the allocate command to do this. It is my current understanding that the -align array64byte is not sufficent here, but I could be incorrect. Also assuming all the vectors are aligned, where is the appropriate place in dosomecalc() to place the !dir$ vector alligned statement? I have read both the data alignment to assist vectorization document as well as the fortran array data and arguments and vectorization, however neither one seemed to handle my case. However I readily admit that I am a chemical engineering grad student and not a computer scientist, so I very well may just not have understood the documents. Any Help is greatly appreciated.
module mymodimplicit none
type cell_data
double precision, allocatable :: loc_r(:,:)
end type cell_data
type vlist
integer :: cnum
double precision :: minx,miny,minz
end type vlist
type list
type(cell_data), allocatable :: cl(:)
type(vlist), allocatable :: cv(:,:)
end type list
type(list) :: listvar
contains
subroutine alloc()
if(conditon1.eq.true)then
deallocate(listvar%cl)
allocate(listvar%cl(0:new_size)deallocate(listvar%cv)
allocate(listvar%cv(0:new_size)
do i = 1,new_size
allocate(listvar%cl(i)%loc_r(3,someothersize)
enddo
elseif(condition2.eq.true)then
do i = 1,cur_size
deallocate(listvar%cl(i)%loc_r)
allocate(listvar%cl(i)%loc_r(3,somenewsize)
enddo
end if
end subroutine alloc
end module mymod
!--- this is another module
subroutine dosomecalc()
use mymod
implicit none
!--- loop over all cells
do i = 0,listvar%ncellT-1
do k=1,26
!---determine this cell
cell_neigh = listvar%cv(k,i)%cnum
if(cell_neigh.gt.i)then
!---minimum image
minx =listvar%cv(k,i)%min_x
miny =listvar%cv(k,i)%min_y
minz =listvar%cv(k,i)%min_z
!--- number of particles in cell i
cell1_num = listvar%cl(i)%num
!--- loop over particles in each cell
do j = 1, cell1_num
x1 = listvar%cl(i)%loc_r(1,j)
y1 = listvar%cl(i)%loc_r(2,j)
z1 = listvar%cl(i)%loc_r(3,j)
!--- number of particles in cell_neigh
cell2_num = listvar%cl(cell_neigh)%num
do l= 1, cell2_num
x2 = listvar%cl(cell_neigh)%loc_r(1,l)
y2 = listvar%cl(cell_neigh)%loc_r(2,l)
z2 = listvar%cl(cell_neigh)%loc_r(3,l)
!--- obtain displacements
!--- apply minimum image here
dx = x2-x1-minx
dy = y2-y1-miny
dz = z2-z1-minz
dr2 = dx*dx+dy*dy+dz*dz
if(dr2.lt.param%rcut2)then
dr2i = 1.0d0/dr2
dr6i = dr2i*dr2i*dr2i
dr12i = dr6i*dr6i
energy = energy + dr12i - dr6i
endif
enddo
enddo
endif
enddo
enddo
end subroutine dosomecalc
