I have a code on host with an offload region to mic, I wanted to profile it using vtune command line option. I am doing as follows:
amplxe-cl -collect advanced-hotspots -target-system=mic-host-launch ./a.out
is there anything other than this is needed? or this is sufficient to do a profiling of my offloaded region to mic? thanks!
Your command line has the bare minimum that is required to run a VTune analysis. However, I recommend adding -search-dir and -source-search-dir switches to the command line to resolves symbols and links them to the sources.
-Sumedh
Thanks!
