Software Archive
Read-only legacy content
17060 Discussions
android.hardware.location.gps Your APK manifest requires capabilities not present on this device.
Leonidas_S_
  • android.hardware.location.gps
this needed by amazon - I submitted an Android App - not amazon app. How add in xdk manifest this???
see shot:attached
Brandon_K_Intel
This error seems to be telling you that the gps feature of you application will not work on that specific device. I don't believe this is an error in the way your application was built unless you did not intend to use the gps Cordova plugin.
Leonidas_S_
So if using HTML5 geolocation ... I am ok... for this Android build app submittdd in amazon?
Pamela_H_Intel
@Leonidas - I agree with Brandon. This is not an error in your application. It is that one or more of your plugin features does not work with your device.
Not all Cordova plugins work with all versions of Android OS. I looked in the Cordova documentation in Geolocation and the only limitation I saw is that Android 2.x has issues with the enableHighAccuracy option, but some phones just do not have the ability to support some plugin features. Do you have another Android device you can test on?
Leonidas_S_
please note the first thread message from amazon - gotten from amazon dashboard submit app - i never tested on device amazon, only in Samsung Note 1 Phone  4.1.2 Android working SUCCESS.
AMAZON PROHIBITS SUBMIT APP TILL FIXED.
well as of Amazon - if this plugin not supported can delete it and use HTML5 GEOLOCATION FEATURES  alone - not use cordova plugin during compilation in XDK...?
PaulF_IntelCorp
See this thread regarding the Kindle Fire. Apparently that device does not include GPS capabilities. Whether or not using the pure HTML5 geo interface will fix the issue is unclear. You'll have to try it to see. BTW -- the standard Cordova geo plugin uses the identical geo API as the standard HTML5 geo API, and uses the built-in HTML5 geo API if it is supported by the webview.
See this app for an example of using the Cordova plugin for geo: https://github.com/xmnboy/hello-cordova
