Software Archive
Read-only legacy content
17060 Discussions
app.consolelog
Tony_T_
I can see my consolelog entries from init.apps.js. Please what is the correct way to modify index_user_scripts.js so I may write to consolelog.
Ad
New Contributor III
use
console.log("hello world");
or sometimes easier/quicker
alert("hello world");
Dale_S_Intel
I think the way it's supposed to work is to set app.LOG to 'true' if you want to see logs from app.consoleLog(), and set it to 'false' if you don't. You can change this anywhere in your code to go back and forth between the two choices.  To be safest, you might want to refer to it as window.app.LOG, and then log things with window.app.consoleLog().
app.consoleLog should act just like console.log, except that it will be a no-op if app.LOG is not 'true'.
Does that help?
Dale
