Software Archive
Read-only legacy content
17060 Discussions
application size is so large
Hardik_V_
Hello, I had worked in in intel xdk 1 year ago.. it was working fine and no any issues regarding certificates and all stuff ..
I have just downloaded a new version of intel xdk 3922 , and tried to create an android application ,it was demanding for adnroid certificate, there is no any straight forward guided path and support given into your site.
I found some helps from other websites and created a certificate and built an ap.. but it contains 25 MB size , where there is nothing in app just a simple text hello word.. , and it is not fair that it contains such a big size..
is there any bug with intel this version?
or I followed the wrong path to build?
Alex_Hang
New Contributor II
Hello sir!
I think you are using crosswalk to build it.
If you target only later Anroid versions ( 4.4 and above I think) You can disable Crosswalk from the build options, this will reduce the size from 25MB to 3-4MB ( That worked for me)
PaulF_IntelCorp
Follow the red (!) link provided on the Build Tile and it will take you to the Build Settings on the Projects tab. From there you can select a certificate for building. Also, help is available under the (?) icon in the upper right.
If you have previously built apps (you mentioned one year ago) then you should have a certificate in the certificate management tool, which is accessible via the "user" icon in the upper right.
Please see the documentation here > https://software.intel.com/en-us/xdk/docs/lp-index < for additional help.
As Alex mentioned, you may have Crosswalk enabled. See this doc page > https://software.intel.com/en-us/xdk/docs/using-the-crosswalk-for-android-build-option < for help.
