Software Archive
Read-only legacy content
17060 Discussions
array dimensioning
Intel_C_Intel
In the following piece of code we tried four ways of dimensioning a simple integer-array. The first two methods (dimensioning by a common-block or a subroutine-argument) cause the error-message:
forrtl: severe (170): Program Exception - stack overflow
..., while the third and fourth way of declaring the bounds of the array work properly - all four ways allocate an array of the same size!
Is there an answer to this mystery??
Code (methods 2-4 not active)
program test
implicit double precision (a-h,o-z)
common /mtest/ msize
msize = 259931
isize = msize
call subtest(isize)
end
subroutine subtest(i)
parameter (lsize = 259931)
! the following two lines fail during run-time:
 dimension itestarray(i)
! dimension itestarray(msize)
! the following two lines don't fail during run-time:
! dimension itestarray(lsize)
! dimension itestarray(259931)
end
The third and fourth methods allocate the array at fixed addresses at link time, whereas the first and second are "automatic arrays" which get allocated on the stack at run-time.
Steve
Intel_C_Intel
Hi
I have the same problem. It seems that the only way to go around this problem is to expand the stack size. I tried with limit and it is not enough. How can I do this?
thanks
Giancarlo
giancarlo,
What operating system are you using? You may want to consider using ALLOCATABLE arrays rather than automatic arrays.
Steve
