Software Archive
Read-only legacy content
17060 Discussions
assigning pointers to a member of a data type
Intel_C_Intel
Hi
I'm having a problem outlined by the following code. I can assign a pointer to a variable within a data type but when it comes to checking if the pointer has been associated with the target a compiler error results. In the following code the pointer "x" can be associated with the data member "thing.dble" however the call to "( associated( x, thing.dble ) )" gives the error.
Any help would be appreciated
Allan
program tester
implicit none
type thingy
real*8 :: dble
integer :: int
end type
real*8, pointer :: x => null()
real*8, target :: y
type(thingy), target :: thing
thing.dble = 10
! pointer "x" can be associated with target "thing.dble"
x => thing.dble
! compiler will not allow the following line to check if the pointer "x"
! is associated with the target
if ( associated( x, thing.dble ) )then
 print*, ' "x" is associated with thing.dble'
 end if
end program
This is an asymmetry in the language - while you can do pointer assignment to a subcomponent of a pointer/target, you can't use ASSOCIATED on the same thing.
Steve
Intel_C_Intel
It seems to me that this asymmetry in the language must be due to some interpretation by the committee regarding the ASSOCIATED inquiry intrinsic because I can't see where it crops up in section 13.14.13 of the F95 standard. In the appended program, I would have guessed from 13.14.13 that Test #1:2 should both be valid F95 because the structure component and array element are both scalars; as noted above Test #1 flunks but Test #2 passes. Further I would have expected Test #3 to fail because z(1), while it dereferences the pointer z, is not itself a pointer (the statement z(1) => array(2) is illegal, for example) and Test #4 would also fail (try z(1:3) => array(2:4)) and while test #5 fails, I would have thought its results should be consistent with Test #3:4. Where can we find the interpretation that allows us to predict these results?
!!DEC$ DEFINE CAUSES_ERROR
program tester
   implicit none
   integer, parameter :: dp = selected_real_kind(15,300)
   type thingy
      real(dp) :: dble
      integer :: int
   end type thingy
   real(dp), pointer :: x => null()
   real(dp), target :: y
   real(dp), target :: array(10)
   real(dp), pointer :: z(:) => null()
   integer i
   type(thingy), pointer :: w
   thing%dble = 10
   x => thing%dble
! Test #1
!DEC$ IF DEFINED(CAUSES_ERROR)
   if ( associated( x, thing%dble ) )then
      print*, ' "x" is associated with thing%dble'
   end if
!DEC$ ELSE
   print*, ' "x" cannot be tested for association with thing%dble'
!DEC$ENDIF
! Try the same thing with an array element
   array(2) = 10
   x => array(2)
! Test #2
   if ( associated( x, array(2) ) )then
      print*, ' "x" is associated with array(2)'
   end if
! Try with an array section
   array = (/(i, i = 1, size(array))/)
   z => array(2:6)
! Test #3
   if ( associated( z(1), array(2) ) )then
      print*, ' ""(1)" is associated with array(2)'
   end if
! Test #4
   if ( associated( z(1:3), array(2:4) ) )then
      print*, ' "z(1:3)" is associated with array(2:4)'
   end if
! Try with pointer to structure
   thing%int = 42
   x => thing%dble
   w => thing
! Test #5
   if ( associated( w%dble, x ) )then
      print*, ' "w%dble" is associated with x'
   end if
!DEC$ ELSE
   print*, ' "w%dble" cannot be tested for association with x'
!DEC$ENDIF
end program tester
Hmm - looking at this again, I may have misunderstood the text and implied an asymmetry that wasn' there. I'll check into this.
Steve
