I was using bldk in simics Atom E6xx virtual system.and I using "gBS->SetVariable" in the bldk,and it successed,
but when I run simics again, I can not get the variable ,and I use "dmpstore" in shell to see the variable,it show it can not be found !
it also happen in the X57+ICH10 platform . what is the problem? whether the bios flash can not be written in simics?
if not,how to solve the problem?
wish your answer!
Does this refer to debugging under the bldk? The only reason I can imagine is that local or unused variables are being optimized away. This can happen with default release or debug builds. The default optimization setting is /O1ib2. You may try to build with /O1 to see if all vaiables are visible for the debugger.
Does this hits the point?
Regards, Hubert.
no,I was write a setup page in EFI, it can not save the setting in setup.once reboot the setting return to default value. and I build it with /01,but it still work either. I wonder to konw this is the simics problem or the bldk problem?
thank you
