Software Archive
Read-only legacy content
17060 Discussions
bugs in cilkprof
Yuan_Tang
I found a possible bug in cilkprof. I installed the cilkprof following instructions in libzca, cilkprof, and pintool (2.10).
When I ran my code with cilkprof as:
$ LD_LIBRAY_PATH=./3rdparty/pintool/intel64/lib-ext/:$LD_LIBRARY_PATH CILKPROF_CC_OUT=heat_2D_P.cc CILKPROF_BB_OUT=heat_2D_P.bb 3rdparty/pintool/pin -t cilkutil/cilkprof/linux64/cilkprof.so -- ./heat_2D_P 200 200
N_SIZE = 200, T_SIZE = 200
a(T+1, J, I) = 0.125 * (a(T, J+1, I) - 2.0 * a(T, J, I) + a(T, J-1, I)) + 0.125 * (a(T, J, I+1) - 2.0 * a(T, J, I) + a(T, J, I-1)) + a(T, J, I)
shorter_duo_sim_obase_bicut_p!
Pochoir ET: consumed time :1127.56ms
pinbin: sprof.h:155: unsigned int sprof_t::get(unsigned int) [with T = sprof_single_t]: Assertion `this->m_table->size() >= i' failed.
Aborted
Best!
-Yuan
Tao_Schardl
I can elicit the same bug from the following variant of fib. (Thanks to Eka Palamadi for the original fib source that demonstrates this bug.)
#include
#include
#include
#include
int fib(int n) {
if (n < 2) {
return n;
int x, y;
x = cilk_spawn fib(n-1);
y = fib(n-2);
cilk_sync ;
return x+y;
int main(int argc, char* argv[]) {
int n = 10;
if (argc > 1) {
n = atoi(argv[1]);
int result = fib(n);
//std::cout << "fib(" << n << ") = " << result << "\n";
printf("fib(%d) = %d\n", n, result);
return 0;
If I compile this program (with icc 12.1.4) and run it with cilkprof, I see:
$LD_LIBRARY_PATH=./3rdparty/pintool/intel64/lib-ext:$LD_LIBRARY_PATH CILKPROF_CC_OUT=fib.cc CILKPROF_BB_OUT=fib.bb 3rdparty/pintool/pin -t cilkutil/cilkprof/linux64/cilkprof.so -- ./fib 10
fib(10) = 55
Aborted
Interestingly, if I comment out the line "#include ", recompile, and rerun with cilkprof, I do not see the error.
Hope this helps,
TB
Barry_T_Intel
I just posted a new copy of cilkprof at download page the which should fix this bug. In short, there was confusion between the capacity of a vector and the size. I think I've got it all cleanedup now.
- Barry
