Software Archive
Read-only legacy content
17060 Discussions
can not open https links
ramin_b_
i use this code in index.html
<p><a href="https://www.facebook.com/">bmi</a></p>
this link show on emulate but dont show when i build my app
please help me add https link
ramin_b_
no anybody here answer to me ?
i use intel xdk and make link in index.html but when build my app https link dont work
Ramith_H_
You need to have "network acesss privilege "
 so when you are building the app you have to select "full network access permission" so that the android system let's your app to use the network
ramin_b_
i have this permissions for networks access
<uses-permission name="android.permission.INTERNET" />
<uses-permission name="android.permission.ACCESS_NETWORK_STATE" />
please if you can help to me
my app work when use http but i need https link
ramin_b_
my site is https://www.bmi.ir this https is Untrusted but i want connect that
ramin_b_
please help me !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ramin_b_
i want trusting all ssl certificate
ramin_b_
 i want ignore all ssl certificates
please send me that's code
ramin_b_
how can use from this code
import java.io.IOException;
import java.net.Socket;
import java.net.UnknownHostException;
import java.security.KeyManagementException;
import java.security.KeyStore;
import java.security.KeyStoreException;
import java.security.NoSuchAlgorithmException;
import java.security.UnrecoverableKeyException;
import java.security.cert.CertificateException;
import java.security.cert.X509Certificate;
import javax.net.ssl.SSLContext;
import javax.net.ssl.TrustManager;
import javax.net.ssl.X509TrustManager;
import org.apache.http.conn.ssl.SSLSocketFactory;
public class MySSLSocketFactory extends SSLSocketFactory {
    SSLContext sslContext = SSLContext.getInstance("TLS");
    public MySSLSocketFactory(KeyStore truststore) throws NoSuchAlgorithmException, KeyManagementException, KeyStoreException, UnrecoverableKeyException {
        super(truststore);
        TrustManager tm = new X509TrustManager() {
            public void checkClientTrusted(X509Certificate[] chain, String authType) throws CertificateException {
            public void checkServerTrusted(X509Certificate[] chain, String authType) throws CertificateException {
            public X509Certificate[] getAcceptedIssuers() {
                return null;
        sslContext.init(null, new TrustManager[] { tm }, null);
    @Override
    public Socket createSocket(Socket socket, String host, int port, boolean autoClose) throws IOException, UnknownHostException {
        return sslContext.getSocketFactory().createSocket(socket, host, port, autoClose);
    @Override
    public Socket createSocket() throws IOException {
        return sslContext.getSocketFactory().createSocket();
ramin_b_
i am new android developer please help me
ramin_b_
If you are here answer to I
Elroy_A_Intel
In order to gain access to third party party websites and web services, you are required to enable the access list under the Project Panel > Build Settings.
I recommend that you include a * (asterisk) in the Access List field on the Project panel for your application. The asterisk allows for communication to any web server or site via your application or AJAX call. You can find the Domain List field with in the Cordova Hybrid Mobile App settings > Build Settings > (desired platform such as Android, iOS etc...)
For more information visit https://software.intel.com/en-us/xdk/articles/cordova-cli-412-domain-whitelisting-with-intel-xdk-for-ajax-and-launching-external-apps.
ramin_b_
thank you very much
i come back for more question please do not leave me alone
ramin_b_
my https ssl is not valid but i want connect to that domain so this way do not help to i
i want ignore ssl certificate
please show correct way to me
ramin_b_
F1 -  F1  - F1
F1 -  F1  - F1
F1 -  F1  - F1
please help to me
ramin_b_
    de.martinreinhardt.cordova.plugins.certificates
how can use from this plugin
ramin_b_
 intel forum work only 8 hour's ?!!!!!!!!!!!!!
ramin_b_
please meke this link open in one android app
<p><a href="https://www.bmi.ir/">bmi</a></p>
ramin_b_
i am online now .
please help
ramin_b_
<!DOCTYPE html>
<html dir="rtl">
  * Please see the included README.md file for license terms and conditions.
    <head>
        <meta charset="UTF-8">
        <title>Blank App Designer Packaged Web App Project Template</title>
        <meta http-equiv="Content-type" content="text/html; charset=utf-8">
        <meta name="viewport" content="width=device-width, minimum-scale=1, initial-scale=1, user-scalable=no">
    </head>
    <body>
  <meta HTTP-EQUIV="REFRESH" content="0; url=https://www.bmi.ir">
    </body>
</html>
ramin_b_
are you developer ? so why can not solve my problem ?
