I bought monitor HP LP2475w hoping i can use it with my mobile computer. The problem is that the card supports only 4:3 resolutions even after installing the latest drivers from the intel site:
MonInfo said:
Monitor
Model name............... HP LP2475w
Manufacturer............. HP
Plug and Play ID......... HWP26F6
Serial number............ CZC84105BY
Manufacture date......... 2008, ISO week 41
EDID revision............ 1.3
Input signal type........ Analog 0.700,0.000 (0.7V p-p)
Sync input support....... Separate, Composite, Sync-on-green
Display type............. RGB color
Screen size.............. 540 x 350 mm (25,3 in)
Power management......... Standby, Suspend, Active off/sleep
Extension blocs.......... None
DDC/CI................... Supported
MCCS revison............. 2.1
Display technology....... TFT
Controller............... Genesis 0x80
Firmware revision........ 0.34
Active power on time..... 4 hours
Current frequency........ 48,30kHz, 59,70Hz
Color characteristics
Default color space...... sRGB
Display gamma............ 2,20
Red chromaticity......... Rx 0,640 - Ry 0,328
Green chromaticity....... Gx 0,300 - Gy 0,600
Blue chromaticity........ Bx 0,149 - By 0,060
White point (default).... Wx 0,313 - Wy 0,328
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 30-94kHz
Vertical scan range...... 48-85Hz
Video bandwidth.......... 210MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1200p at 60Hz
Modeline............... "1920x1200" 154,000 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 75Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768p at 60Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 870p at 75Hz - Apple Mac II
1280 x 960p at 60Hz - VESA STD
1600 x 1000p at 60Hz - VESA STD
1600 x 1200p at 60Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
1920 x 1200p at 60Hz - VESA STD
Report information
Date generated........... 15.11.2008 .
Software revision........ 2.11.0.752
Raw data................. 00,FF,FF,FF,FF,FF,FF,00,22,F0,F6,26,01,01,01,01,29,12,01,03,6E,36,23,78,EE,CE,50,A3,54,4C,99,26,
......................... 0F,50,54,A5,6B,80,81,40,A9,00,A9,40,B3,00,D1,00,01,01,01,01,01,01,28,3C,80,A0,70,B0,23,40,30,20,
......................... 36,00,22,60,21,00,00,1A,00,00,00,FC,00,48,50,20,4C,50,32,34,37,35,77,0A,20,20,00,00,00,FD,00,30,
......................... 55,1E,5E,15,00,0A,20,20,20,20,20,20,00,00,00,FF,00,43,5A,43,38,34,31,30,35,42,59,0A,20,20,00,58
Should be able to get 1920x1200. Try using the sticky thread at the top of this Forum, and use the DTD
28 3C 80 A0 70 B0 23 40 30 20 36 00 22 60 21 00 00 1A
If this doesn't work, it's also entirely possible Toshibahas disabled 1920x1200 in the BIOS. To determine if this is true, try 1918x1200:
28 3C7E A2 70 B0 23 40 30 20 36 00 22 60 21 00 00 1A
Aaron Brezenski, you are a lifesaver! any thanks for sympathy!!! Toshibahas disabled 1920x1200 but 1918x1200 works fine!
I have read about EDID problems and HDCP problems among some LCD monitors and some ATI cards, can anyone shed some light on this for me?
Brandon
MonInfo said:
Monitor
Report information
![](/skins/images/45C6C2D737ED71F4C51F0145C8CB1E9C/responsive_peak/images/icon_anonymous_message.png)
