Software Archive
Read-only legacy content
17060 Discussions
cannot access to camera streams by Open CV
tommaso_c_
Hi!
I'm tring to stream the R200 with Open CV, using this code
http://www.samontab.com/web/2016/04/interfacing-intel-realsense-f200-with-opencv/
I can build the code on Visual Studio but the windows (screens) of RGB, depth and IR are completely black and it's to work.
Ideas?
Johannes_V_
The code looks fine. I suppose its a realsense problem.
Do the samples from the SDK sample browser work?
tommaso_c_
yes they work good! It doesn't work just when I try to open from Open CV
samontab
Valued Contributor II
Try saving the images to disk with cv::imwrite, and check those images with a photo viewer. Maybe you have some issues with the highgui library (the library part dedicated to drawing on a window)
You can also check the contents of the data coming from the RealSense camera at the appropriate time.
Maybe there's a problem at the conversion of the formats. Read the comment in the page.
And, of course, you need light :)
tommaso_c_
I dont Think is the format. I am not able to Switch on the R200 from open CV.
samontab
Maybe you are not linking the correct libraries?
OpenCV really has nothing to do with the camera acquisition...
IEBEI
Here is a simplified version of what works for me
PXCImage *color_image = sample->color;
PXCImage::ImageInfo color_info = color_image->QueryInfo();
PXCImage::ImageData color_data;
color_image->AcquireAccess(PXCImage::ACCESS_READ, PXCImage::PIXEL_FORMAT_RGB32, &color_data);
IplImage* colorimg = cvCreateImageHeader(cvSize(color_info.width, color_info.height), 8, 4);
cvSetData(colorimg, color_data.planes[0], color_info.width * 4 * sizeof(pxcBYTE));
Mat color_img_mat = cvarrToMat(colorimg);
color_image->ReleaseAccess(&color_data);
tommaso_c_
Changing the format, I got a better resolution for the color And depth stream but the IR still dont work. I will try your code! If it doesnt work I ll check the libraries again
tommaso_c_
Ok I finally Found the solution! Actually as You told it was a problem of formats! In The near future I m going to post the entire code. Thank You everyone
samontab
Remember to set the IR stream to 8 bits (PXCImage::PIXEL_FORMAT_Y8), in OpenCV you use CV_8UC1.
And also set the pitch/step in both directions of the conversion, like this in each case:
data.pitches[0] = cvImage.step
cv::Mat ocvImage = cv::Mat(cv::Size(width, height), type, data.planes[0], data.pitches[0]);
Johannes_V_
forgive me my questions, but where to set the stream to 8 bits?
as for now i only activate the stream by the sense manager over
PXCSenseManager *sm=PXCSenseManager::CreateInstance();
sm->EnableStream(PXCCapture::STREAM_TYPE_IR,320,240);
thank you samontab
samontab
