Software Archive
Read-only legacy content
17060 Discussions
cannot detect hand tracking (intel realsense camera)
novira_p_
hello, i want to disgust about my problem.
my realsense camera cannot detect hand tracking, if my hand close with the camera about < 1 cm, the camera can detect my finger but not clearly, if i compare with my friend cameras, my infrared light is very dim. please gibe me a solution.
thank you
samontab
Valued Contributor II
You can try changing the IVCAM parameters. Take a look here:
https://software.intel.com/en-us/forums/topic/537872
novira_p_
I try this software but after I install and run then the program encountered an error like  "program not responding" and I try in another computer the problem is the same. please give me a solution.
thank you
novira_p_
hello, samontab
ivcam finally able to walk, and the result remains the same, it does not look anything dark.like this.
novira_p_
and if I use the SDK realsense hand viewer then detected
novira_p_
if my hand approached distance of 1 cm, the camera can be detected like this
samontab
Try setting the motionrangetradeoff parameter to 100, and laserpower to 16.
