Software Archive
Read-only legacy content
17060 Discussions
I need help,I have installed SDK but can,t run sample application
林松_庞_
In accordance with https://software.intel.com/zh-cn/intel-realsense-sdk/download ,I was downloaded and installed DCM2.0,
Next, Installed SDK 5.0.3.187777 and reboot after intelled.
Now, I run sample application ,there is a error :
And the next picture to show my device manager info and DCM installed info.
Added: In 2D application to run RGB camera is no error, but in 3D mode to run depth camera will make application init falied.
zhang_y_
Hi 松林 庞,
Please provider error information. I think many guys help you when you translate ch to en.
Colleen_C_Intel
Unfortunately your user directory name can ONLY contain english alphabet characters.
林松_庞_
Hi Colleen, I used default path(C:\Program Files (x86)\Intel\RSSDK) to install.Is it OK ?
Colleen_C_Intel
the problem is the user folder. Can you create a user with an English name and try installing again for that new user and see if the samples run.
林松_庞_
Thanks ,I'll reinstalled to an English folder to test.
林松_庞_
Hi Colleen, I used The Chinese version of widnows Windows8.1 pro for 64bit,  is this error?
Colleen_C_Intel
Chinese version of 8.1 pro 64 bit should be fine.
林松_庞_
Hi, Colleen.
No, Chinese version of 8.1 pro 64 bit ,user folder name is Chinese.
Did you test this version? Are you using English version of Windows?
林松_庞_
Thans for all helps! I run the application not in 4th Generation Intel® Core™ Processor.
