Software Archive
Read-only legacy content
17060 Discussions
cannot open my xdk project in 3491 when updated from 3400
Surya_K_
it says plugin directory and project file mismatch
when i click on use driretory
Cannot read property 'scratchDir' of undefined
  • unknown
You can cancel plugin resolution and exit this project.
this error shows up
PaulF_IntelCorp
There is no picture attached to your post. Please repost with the picture.
When you see that plugin message, it generally works best to select use project rather than use directory. In the worst case, delete the plugins directory inside your project file (after you have exited the XDK) and then restart the XDK and open your project.
Jerome_P_
I too am having issues opening my projects.
The only one I can edit is whatever one is open on boot. If I try to switch to another project I get 1 of 2 results:
1) nothing happens, changing projects does nothing
2) complaints about plugins, and then nothing
If i try to open a new project, it forever loads (waiting 20 minutes and it was still loading)
UPDATE: If I select my project from the drop down menu, close XDK and re-open it...it sometimes loads. It also sometimes just loads a random project. I tried reinstalling, no luck. This is messed :(
PaulF_IntelCorp
Jerome, I sent you a private message.
Surya_K_
I am experiencing this issue aswell
