After I updated MPSS and ICC to version 3.42 and 15.0.1 respectively, I cannot compile Xeon Phi program which uses iostream. For example, when I tried to compile the following program with "icc test.cpp", I receive the error which says "/usr/linux-k1om-4.7/linux-k1om/../x86_64-k1om-linux/include/c++/4.7.0/iostream(39): catastrophic error: *MIC* cannot open source file "bits/c++config.h". Can you please give me advice about the way to remove the error.
#include <iostream>
#include <stdio.h>
int main(int argc, char * argv[]){
std::cout << "Hello World from host!" << std::endl;
#pragma offload target(mic:0)
printf("test");
fflush(0);
std::cout << "Bye" << std::endl;
I thought I had come across this in the past but have not been able to find any information I may have collected at the time. I cannot reproduce this today although I am still on MPSS 3.4.1. I included details below on what I see in connection with the missing include.
Can you check whether the same details that I have shown below exist on your system?
$ icc -V Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.1.133 Build 20141023 $ icc -H u538814.cpp 2>&1 | grep c++config.h .. /usr/include/c++/4.4.7/x86_64-redhat-linux/bits/c++config.h .. /usr/linux-k1om-4.7/linux-k1om/../lib/gcc/x86_64-k1om-linux/4.7.0/include-fixed/bits/c++config.h
The above path to the header has an underlying sym-link into /opt/mpss:
$ ls -lrt /usr/linux-k1om-4.7/linux-k1om/../lib/gcc/x86_64-k1om-linux/4.7.0/include-fixed/bits lrwxrwxrwx 1 root root 77 Oct 26 05:56 /usr/linux-k1om-4.7/linux-k1om/../lib/gcc/x86_64-k1om-linux/4.7.0/include-fixed/bits -> /opt/mpss/3.4.1/sysroots/k1om-mpss-linux/usr/include/c++/k1om-mpss-linux/bits
The actual header resides here:
$ ls -l /opt/mpss/3.4.1/sysroots/k1om-mpss-linux/usr/include/c++/k1om-mpss-linux/bits/*config.h -rw-r--r-- 1 root root 45527 Oct 17 16:05 /opt/mpss/3.4.1/sysroots/k1om-mpss-linux/usr/include/c++/k1om-mpss-linux/bits/c++config.h
I was able to remove the error. I have another machine with Xeon Phi. I copied /usr/linux-k1om-4.7/linux-k1om/../x86_64-k1om-linux/include/c++/4.7.0/bits/c++config.h in the machine into the corresponding directory in the problematic machine. Then the error was removed. Is it okay to use c++config.h in the other system?
And I got the same details as your results. The results of my system are the following.
$ icc -H test.cpp 2>&1 | grep c++config.h .. /usr/include/c++/4.4.6/x86_64-redhat-linux/bits/c++config.h .. /usr/linux-k1om-4.7/linux-k1om/../x86_64-k1om-linux/include/c++/4.7.0/bits/c++config.h
$ ls -lrt /usr/linux-k1om-4.7/linux-k1om/../lib/gcc/x86_64-k1om-linux/4.7.0/include-fixed/bits lrwxrwxrwx 1 root root 77 Jan 15 11:52 /usr/linux-k1om-4.7/linux-k1om/../lib/gcc/x86_64-k1om-linux/4.7.0/include-fixed/bits -> /opt/mpss/3.4.2/sysroots/k1om-mpss-linux/usr/include/c++/k1om-mpss-linux/bits $ ls -l /opt/mpss/3.4.2/sysroots/k1om-mpss-linux/usr/include/c++/k1om-mpss-linux/bits/*config.h -rw-r--r-- 1 root root 45527 Nov 25 09:34 /opt/mpss/3.4.2/sysroots/k1om-mpss-linux/usr/include/c++/k1om-mpss-linux/bits/c++config.h
Interesting. So are the results you showed from the system you suffered the error on *before* you copied the file from your other system or are those from your other (I presume working) system?
I believe copying the file is ok but it leaves an uneasy feeling of what else might be missing on that system. Not knowing why it was missing leaves open the possibility of a glitch installing MPSS and has me wondering whether it is prudent to redo the MPSS installation on that system rather than copying the file.
Yes. I copied c++config.h from another system where MPSS 2.1 is installed. I also found that this error can be removed by copying c++config.h in /opt/mpss/3.4.2/sysroots/k1om-mpss-linux/usr/include/c++/bits/c++config.h to /opt/mpss/3.4.2/sysroots/k1om-mpss-linux/usr/include/c++/k1om-mpss-linux/bits/ within the problematic machine.
Anyway, I'll reinstall MPSS and check if the error occurs again.
Thank you.
