Software Archive
Read-only legacy content
17061 Discussions
EnableHand() not working with Cocos2d-x
IPetr1
EnableHand() returns PXC_STATUS_ITEM_UNAVAILABLE when using with Cocos2d-x. It works fine on the same computer as a non-Cocos2d-x project.
Steps to reproduce:
1) Download http://www.cocos2d-x.org/filedown/cocos2d-x-2.2.6.zip
2) Open cocos2d-win32.vc2012.sln project.
3) Right click HelloCpp in Solution Explorer to Set as StartUp project.
4) Integrate Property Sheet "c:\Program Files (x86)\Intel\RSSDK\props\VS2010-13.Integration.MD.props" to HelloCpp's Debug configuration.
5) Find HelloCpp's main.cpp and replace it with the following code:
#include "main.h"
#include "pxcdefs.h"
#include "pxcfaceconfiguration.h"
#include "pxcsensemanager.h"
#include "pxcspeechrecognition.h"
#include "pxcspeechsynthesis.h"
int APIENTRY _tWinMain(HINSTANCE hInstance,
    HINSTANCE hPrevInstance,
    LPTSTR    lpCmdLine,
    int       nCmdShow)
    UNREFERENCED_PARAMETER(hPrevInstance);
    UNREFERENCED_PARAMETER(lpCmdLine);
    PXCSession *g_session = PXCSession_Create();
    PXCSenseManager *pp = g_session->CreateSenseManager();
    pxcStatus status = pp->EnableHand();
    if (status != PXC_STATUS_NO_ERROR)
        MessageBox(NULL, L"EnableHand not working", L"Error", MB_OK);
    else
        MessageBox(NULL, L"EnableHand working", L"OK", MB_OK);
    return 0;
6) Click HelloCpp and hit F5
It will complain about:
LINK : fatal error LNK1104: cannot open file 'libpxcutilsmd_d.lib'
It is because Platform Toolset is set to v120_xp.
7) Copy files from "c:\Program Files (x86)\Intel\RSSDK\sample\common\lib\Win32\v120" to "c:\Program Files (x86)\Intel\RSSDK\sample\common\lib\Win32\v120_xp".
Note: It would be nice to include real v120_xp folder in SDK.
8) Hit F5 again.
9) It displays "EnableHand not working" message.
Output windows displays the following error, I think it is related to the issue:
First-chance exception at 0x77D1F4FA (ntdll.dll) in HelloCpp.exe: 0xC0000139: Entry Point Not Found.
Warm regards,
Ivan
IPetr1
Those are working fine in the same project when using instead of EnableHand():
EnableEmotion()
Enable3DSeg()
EnableFace()
EnableTracker()
SDK info details:
Intel(R) RealSense(TM) SDK 3.1.0.25181
Intel(R) RealSense(TM) SDK Runtime 3.1.0.25181
Intel(R) RealSense(TM) Depth Camera Manager 1.2.14.24922
Intel(R) RealSense(TM) 3D Camera 0224
Jonathan_M_Intel
Developing under the v120_xp is not recommended.  Try recompiling using v120.  The SDK is only validated to operate on Windows 8.1, not Windows XP, so there is no need to use the v120_xp toolset to force backwards compatibility.
IPetr1
Not working with v120 either.
Jonathan_M_Intel
Can you open the SDK Information Viewer, click Save on the menu bar, and post or private message that txt file to me?
IPetr1
I've sent you SDK info as a private message.
