Software Archive
Read-only legacy content
17060 Discussions
compile with -mmic gives an error "cannot open source file"
Valjean__Jean
I use gsl libraries in my code. When I compile it with sse4.2, avx, avx2 everything works fine. When I try to compile with -mmic an error is coming up.
$ icpc -mmic test.cpp -lgsl -lgslcblas
test.cpp(4): catastrophic error: cannot open source file "gsl/gsl_statistics_long_double.h"
What should I do to jump over this error ?
If you have an idea please detail it a bit more because I'm just an enthusiast, not a professional.
thank you
ps:
I found a similar topic about other library, but is too old (2014) ant the links are not working anymore.
JJK
New Contributor III
how did you build the gsl library? and which version of it? Several years back I compiled gsl 1.16 for the mic without too many problems (https://software.intel.com/en-us/forums/intel-many-integrated-core/topic/520608)
I just downloaded gsl 2.6 and it also compiles OK for the mic using
./configure --host=x86_64-unknown-linux-gnu CC=icc CXX=icpc CFLAGS="-mmic"
Valjean__Jean
It works, thank you for your answer, take care keep safe !
Zimin__Gleb
I have the same error, but I've already tried to build gsl lib with "-mmic" flag.
May be the problem is that I've installed this lib not in the default place. Here is the example of command.
$ icc -I/home/gzimin/gsl/usr/local/lib/ -fopenmp -mmic -lgsl calc_mic_native.c -o calc_native_mic
But I get
calc_mic_native.c(33): catastrophic error: cannot open source file "gsl/gsl_errno.h"
Valjean__Jean
Take my answer as from an enthusiast, I don't know what is the best way but for me was working as bellow described.
According to gsl documentation the folder should be "/usr/local/lib/include/", in my case was only "/usr/local/lib/". You can adjust this on the last step "make install" by writing the path where you want gsl to be installed (-destination folder). If you didn't make it, just search for the output (the gsl libraries .so) using find and export the path
export SINK_LD_LIBRARY_PATH=/usr/local/lib
export LD_LIBRARY_PATH=/usr/local/lib
You can also do a copy of the compiled library in the coprocessor with "# scp -r /usr/local/lib/* mic0:/lib64/" but it is not persistent over reboot (and the OS must be captured according to mpss documentation chapter 7.2.2 pag 112)
I also found in internet something to add when compile  "-L/usr/local/lib -lgsl ${GSL_CBLAS_LIB} -lm -lm" but for me was already working, I didn't try it.
I hope it helps
JJK
New Contributor III
most likely the gsl header files are installed in /home/gzimin/gsl/usr/local/include, instead of /home/gzimin/gsl/usr/local/lib
Try using
icc -I/home/gzimin/gsl/usr/local/include/ -fopenmp -mmic -L/home/gzimin/gsl/usr/local/lib -lgsl calc_mic_native.c -o calc_native_mic
