Software Archive
Read-only legacy content
17060 Discussions
compiling MS Fortran 5. 1 code in DVF
kvrichardson
Hello.
I'm bringing thousand of lines of MS Fortran 5.1 code into the DVF environment to try to compile it. Do I follow the guidelines for porting MS Powerstation for the most part, or are there additional steps I need to take? Where would I find those steps?
My first compile had 3000 errors and 5000 warnings!
Is DVF the best place for me to maintain and update this code, or should I be in an old program like Codeview or Codeview for Windows?
Any starting tips would be appreciated!
Keith Richardson
Visual Fortran is a fine environment to use.
What kinds of errors are you seeing? For there to be that many, something seriously is wrong. It should not need a significant porting effort.
Steve
Intel_C_Intel
Hi Keith,
I've ported lots of code (Lahey; MS Fortran; Unix->PC; etc) and I think in the situation you've described I'm sure you'll find that one of the early compiler errors is causing most of the rest of the "errors". Errors in "include" or "common" statements that appear in multiple source files for example.
Don't bother with Codeview, it was good in its day, debugging in DVF/CVF is better and easier.
One of the few porting differences I keep tripping on is the default recordlength (RECL) in DVF is 4 bytes.
Good luck, Guy
kvrichardson
The port to DVF 6.5A going well now. My list of things to correct is very short....removing "$storage:2" and a few errors in common took care of most of my issues.
Thanks !
Keith
Keith
