Software Archive
Read-only legacy content
17060 Discussions
compiling a simple program
TK
i have a simple program which includes:
#pragma offload target(mic)
i try to compile it using the following:
icc -offload-build test.c -o test
i get:
icc: command line remark #10148: option 'offload-build' not supported
how should i compile my program? thanks!
Ravi_N_Intel
-offload-build is obsoleted.  Just use
icc -o test test.c.
If your program has offload code the compiler will generate the necessary code to run on the card.
TK
Thanks Ravi!
