Software Archive
Read-only legacy content
17061 Discussões
cordova 5.1.1 CLI splashscreen in ios
vinay_m_
Principiante
918 Visualizações
Im using latest version of intel xdk which is incorporated with cordova 5.1.1. I built an application by adding all splashscreen for ios in build settings and also i added cordova splashscreen plugin but i'm still getting cordova as my application splashscreen.Please let me know the solution or fix for this. Thanks in advance :)
7 Respostas
Rakshith_K_Intel
Funcionário
918 Visualizações
Which type of ios device are you seeing this issue on?
vinay_m_
Principiante
918 Visualizações
Hi Rakshith Krishnappa
I checked in iPhone 5s, iPhone 6 and iPad but none of them are working.
John_H_Intel2
Funcionário
918 Visualizações
Did you set ALL the icons/splashscreens in the Project Settings?
Are you doing a Cordova build?
vinay_m_
Principiante
918 Visualizações
Hi John,
Yes I set all the icons/Splashscreens in project settings and doing a cordova build.
John_H_Intel2
Funcionário
918 Visualizações
I tried looking at things to see if I could see whats happening, but I could not find any iOS builds for the same login you are using here in the forums. Are you using a different login for the XDK?
vinay_m_
Principiante
918 Visualizações
i'm using intelxdk.tcs@gmail.com
John_H_Intel2
Funcionário
918 Visualizações
Check the contents of your /images/ folder. It seems to be empty in the cloud.
Responder
