Software Archive
Read-only legacy content
17060 Discussions
cordova-progressIndicator plugins not install
ganesh_v_
Third-parti-plugins  cordova-progressIndicator plugins not install
https://github.com/pbernasconi/cordova-progressIndicator.git
Anusha_M_Intel1
It looks like there is a proxy issue that is not allowing the XDK to checkout the plugin. Try downloading the plugin and importing it as a local plugin.
Anusha_M_Intel1
if you are doing a local import, you need to place the downloaded plugin outside the 'www' directory or your 'plugins' directory.
ganesh_v_
Error: Provisioning profile is missing from the configuration file
how to find configuration file
ganesh_v_
  • Error: Provisioning profile is missing from the configuration file
how to fin this file
PaulF_IntelCorp
@Ganesh -- you have to create a provisioning file with your Apple Developer account and add it to your project using the Build Settings on the iOS tab on the Projects tab.
