Software Archive
Read-only legacy content
17060 Discussions
cordova-sqlite-legacy Plugin
nicolas_r_
Hi im using cordoba-sql-legacy plugin ver 0.7.18, and i follow a tutorial but i don't know if is working because the emulator console didn't give me any information, i also try adding a "alert" but it shows nothing so maybe is something wrong on my code i really don't know. as framework im  using Ionic with angularJS. any info about i will appreciate a lot thanks =)
My app.js
var db = null;
var example = angular.module('myApp', ['ionic', 'ngCordova'])
.run(function($ionicPlatform, $cordovaSQLite) {
        $ionicPlatform.ready(function() {
            if(window.cordova && window.cordova.plugins.Keyboard) {
                cordova.plugins.Keyboard.hideKeyboardAccessoryBar(true);
            if(window.StatusBar) {
                StatusBar.styleDefault();
            db = $cordovaSQLite.openDB("my.db");
            $cordovaSQLite.execute(db, "CREATE TABLE IF NOT EXISTS people (id integer primary key, firstname text, lastname text)");
example.controller("ExampleController", function($scope, $cordovaSQLite) {
    $scope.insert = function(firstname, lastname) {
        var query = "INSERT INTO people (firstname, lastname) VALUES (?,?)";
        $cordovaSQLite.execute(db, query, [firstname, lastname]).then(function(result) {
            console.log("INSERT ID -> " + result.insertId);
            alert("result.insertId");
        }, function(error) {
            console.log(error);
    $scope.select = function(lastname) {
        var query = "SELECT firstname, lastname FROM people WHERE lastname = ?";
        $cordovaSQLite.execute(db, query, [lastname]).then(function(result) {
            if(result.rows.length > 0) {
                console.log("SELECTED -> " + result.rows.item(0).firstname + " " + result.rows.item(0).lastname);
            } else {
                console.log("No results found");
            console.log(error);
My index.html
 <div id="campa_de_sangre" class="upage-content vertical-col left hidden"></div>
                <div id="consejos" class="upage-content vertical-col left hidden">
                    <ion-content ng-controller="ExampleController">
                        <button class="button" ng-click="insert('nic','rad')">Insertar</button>
                        <button class="button" ng-click="select('rad')">Selecet</button>
                    </ion-content>
                </div>
Elroy_A_Intel
Intel XDK Emulate Tab only support the standard Cordova plugins. You will need to test any other plugins on a physical device.
nicolas_r_
but the alert in the could should apear even when the pluging do nothing?
Elroy_A_Intel
The alert is contained within your sqllite code block so it will not execute if the plugin or functionality isn't accessible.
PaulF_IntelCorp
Nicolas -- please use the Debug tab to test an app that contains non-core plugins.
nicolas_r_
i test on real device and not event the alert show
PaulF_IntelCorp
Might have to use the CDT panel to see what is happening. > https://developers.google.com/web/tools/chrome-devtools/
