Software Archive
Read-only legacy content
17061 Discussions
core dump after vainfo on ubuntu 16.04 with MediaServerStudioEssentials2017R2
ERwan_l_
I want fix it , can you help me
libva info: VA-API version 0.99.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
vainfo: VA-API version: 0.99 (libva 1.67.0.pre1)
vainfo: Driver version: 16.5.1.59511-ubit
vainfo: Supported profile and entrypoints
      VAProfileH264ConstrainedBaseline:    VAEntrypointVLD
      VAProfileH264ConstrainedBaseline:    VAEntrypointEncSlice
      VAProfileH264ConstrainedBaseline:    <unknown entrypoint>
      VAProfileH264Main               :    VAEntrypointVLD
      VAProfileH264Main               :    VAEntrypointEncSlice
      VAProfileH264Main               :    <unknown entrypoint>
      VAProfileH264High               :    VAEntrypointVLD
      VAProfileH264High               :    VAEntrypointEncSlice
      VAProfileH264High               :    <unknown entrypoint>
      VAProfileMPEG2Simple            :    VAEntrypointEncSlice
      VAProfileMPEG2Simple            :    VAEntrypointVLD
      VAProfileMPEG2Main              :    VAEntrypointEncSlice
      VAProfileMPEG2Main              :    VAEntrypointVLD
      VAProfileVC1Advanced            :    VAEntrypointVLD
      VAProfileVC1Main                :    VAEntrypointVLD
      VAProfileVC1Simple              :    VAEntrypointVLD
      VAProfileJPEGBaseline           :    VAEntrypointVLD
      VAProfileJPEGBaseline           :    VAEntrypointEncPicture
      VAProfileVP8Version0_3          :    VAEntrypointEncSlice
      VAProfileVP8Version0_3          :    VAEntrypointVLD
      VAProfileVP8Version0_3          :    <unknown entrypoint>
      VAProfileVP9Profile0            :    <unknown entrypoint>
      <unknown profile>               :    VAEntrypointVideoProc
      VAProfileNone                   :    VAEntrypointVideoProc
      VAProfileNone                   :    <unknown entrypoint>
Segmentation fault (core dumped)
cat /proc/cpuinfo
processor    : 0
vendor_id    : GenuineIntel
cpu family    : 6
model        : 58
model name    : Intel(R) Core(TM) i7-3740QM CPU @ 2.70GHz
stepping    : 9
microcode    : 0x16
cpu MHz        : 1233.667
cache size    : 6144 KB
physical id    : 0
siblings    : 8
core id        : 0
cpu cores    : 4
apicid        : 0
initial apicid    : 0
fpu        : yes
fpu_exception    : yes
cpuid level    : 13
wp        : yes
flags        : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm epb tpr_shadow vnmi flexpriority ept vpid fsgsbase smep erms xsaveopt dtherm ida arat pln pts
bugs        :
bogomips    : 5387.79
clflush size    : 64
cache_alignment    : 64
address sizes    : 36 bits physical, 48 bits virtual
power management:
 strace vainfo
execve("/usr/bin/vainfo", ["vainfo"], [/* 80 vars */]) = 0
brk(NULL)                               = 0x11d0000
access("/etc/ld.so.nohwcap", F_OK)      = -1 ENOENT (No such file or directory)
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f80cf1f4000
access("/etc/ld.so.preload", R_OK)      = -1 ENOENT (No such file or directory)
open("/usr/lib64/tls/x86_64/libva.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib64/tls/x86_64", 0x7fff08b75ae0) = -1 ENOENT (No such file or directory)
open("/usr/lib64/tls/libva.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib64/tls", 0x7fff08b75ae0)  = -1 ENOENT (No such file or directory)
open("/usr/lib64/x86_64/libva.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib64/x86_64", 0x7fff08b75ae0) = -1 ENOENT (No such file or directory)
open("/usr/lib64/libva.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\240'\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=122128, ...}) = 0
mmap(NULL, 2219264, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f80cedb3000
mprotect(0x7f80cedd0000, 2097152, PROT_NONE) = 0
mmap(0x7f80cefd0000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1d000) = 0x7f80cefd0000
close(3)                                = 0
open("/usr/lib64/libva-x11.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\36\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=32272, ...}) = 0
mmap(NULL, 2127576, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f80cebab000
mprotect(0x7f80cebb2000, 2097152, PROT_NONE) = 0
mmap(0x7f80cedb2000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x7f80cedb2000
close(3)                                = 0
open("/usr/lib64/libXext.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/tls/x86_64/libXext.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib/tls/x86_64", 0x7fff08b75a80) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/tls/libXext.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib/tls", 0x7fff08b75a80) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/x86_64/libXext.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib/x86_64", 0x7fff08b75a80) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libXext.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=134320, ...}) = 0
mmap(NULL, 134320, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7f80cf1d3000
close(3)                                = 0
open("/usr/lib/x86_64-linux-gnu/libXext.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\2205\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=73640, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f80cf1d2000
mmap(NULL, 2169496, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f80ce999000
mprotect(0x7f80ce9aa000, 2093056, PROT_NONE) = 0
mmap(0x7f80ceba9000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x10000) = 0x7f80ceba9000
close(3)                                = 0
open("/usr/lib64/libXfixes.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libXfixes.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/lib/x86_64-linux-gnu/libXfixes.so.3", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0000\25\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=22584, ...}) = 0
mmap(NULL, 2117896, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f80ce793000
mprotect(0x7f80ce798000, 2093056, PROT_NONE) = 0
mmap(0x7f80ce997000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x7f80ce997000
close(3)                                = 0
open("/usr/lib64/libX11.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libX11.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/lib/x86_64-linux-gnu/libX11.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0p\210\1\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=1285552, ...}) = 0
mmap(NULL, 3382584, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f80ce459000
mprotect(0x7f80ce58e000, 2097152, PROT_NONE) = 0
mmap(0x7f80ce78e000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x135000) = 0x7f80ce78e000
close(3)                                = 0
open("/usr/lib64/libva-drm.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0000\r\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=9600, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f80cf1d1000
mmap(NULL, 2104704, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f80ce257000
mprotect(0x7f80ce259000, 2093056, PROT_NONE) = 0
mmap(0x7f80ce458000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x7f80ce458000
close(3)                                = 0
open("/usr/lib64/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/x86_64-linux-gnu/libdl.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\240\r\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=14608, ...}) = 0
mmap(NULL, 2109680, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f80ce053000
mprotect(0x7f80ce056000, 2093056, PROT_NONE) = 0
mmap(0x7f80ce255000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f80ce255000
close(3)                                = 0
open("/usr/lib64/libdrm.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\360;\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=64704, ...}) = 0
mmap(NULL, 2162472, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f80cde43000
mprotect(0x7f80cde52000, 2097152, PROT_NONE) = 0
mmap(0x7f80ce052000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xf000) = 0x7f80ce052000
close(3)                                = 0
open("/usr/lib64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/x86_64-linux-gnu/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0P\t\2\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=1864888, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f80cf1d0000
mmap(NULL, 3967392, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f80cda7a000
mprotect(0x7f80cdc39000, 2097152, PROT_NONE) = 0
mmap(0x7f80cde39000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1bf000) = 0x7f80cde39000
mmap(0x7f80cde3f000, 14752, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f80cde3f000
close(3)                                = 0
open("/usr/lib64/libxcb.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libxcb.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/lib/x86_64-linux-gnu/libxcb.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260\226\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=137728, ...}) = 0
mmap(NULL, 2233000, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f80cd858000
mprotect(0x7f80cd879000, 2093056, PROT_NONE) = 0
mmap(0x7f80cda78000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x20000) = 0x7f80cda78000
close(3)                                = 0
open("/usr/lib64/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/x86_64-linux-gnu/librt.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0!\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=31712, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f80cf1cf000
mmap(NULL, 2128832, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f80cd650000
mprotect(0x7f80cd657000, 2093056, PROT_NONE) = 0
mmap(0x7f80cd856000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x7f80cd856000
close(3)                                = 0
open("/usr/lib64/libm.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libm.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/x86_64-linux-gnu/libm.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0V\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=1088952, ...}) = 0
mmap(NULL, 3178744, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f80cd347000
mprotect(0x7f80cd44f000, 2093056, PROT_NONE) = 0
mmap(0x7f80cd64e000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x107000) = 0x7f80cd64e000
close(3)                                = 0
open("/usr/lib64/libXau.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libXau.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/lib/x86_64-linux-gnu/libXau.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0P\16\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=14456, ...}) = 0
mmap(NULL, 2109720, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f80cd143000
mprotect(0x7f80cd145000, 2097152, PROT_NONE) = 0
mmap(0x7f80cd345000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f80cd345000
close(3)                                = 0
open("/usr/lib64/libXdmcp.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libXdmcp.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/lib/x86_64-linux-gnu/libXdmcp.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\320\21\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=22640, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f80cf1ce000
mmap(NULL, 2117784, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f80ccf3d000
mprotect(0x7f80ccf42000, 2093056, PROT_NONE) = 0
mmap(0x7f80cd141000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x7f80cd141000
close(3)                                = 0
open("/usr/lib64/libpthread.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libpthread.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/x86_64-linux-gnu/libpthread.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260`\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=138696, ...}) = 0
mmap(NULL, 2212904, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f80ccd20000
mprotect(0x7f80ccd38000, 2093056, PROT_NONE) = 0
mmap(0x7f80ccf37000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x17000) = 0x7f80ccf37000
mmap(0x7f80ccf39000, 13352, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f80ccf39000
close(3)                                = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f80cf1cd000
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f80cf1cc000
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f80cf1cb000
arch_prctl(ARCH_SET_FS, 0x7f80cf1cc700) = 0
mprotect(0x7f80cde39000, 16384, PROT_READ) = 0
mprotect(0x7f80ccf37000, 4096, PROT_READ) = 0
mprotect(0x7f80cd141000, 4096, PROT_READ) = 0
mprotect(0x7f80cd345000, 4096, PROT_READ) = 0
mprotect(0x7f80cd64e000, 4096, PROT_READ) = 0
mprotect(0x7f80cd856000, 4096, PROT_READ) = 0
mprotect(0x7f80cda78000, 4096, PROT_READ) = 0
mprotect(0x7f80ce255000, 4096, PROT_READ) = 0
mprotect(0x7f80ce78e000, 4096, PROT_READ) = 0
mprotect(0x7f80ce997000, 4096, PROT_READ) = 0
mprotect(0x7f80ceba9000, 4096, PROT_READ) = 0
mprotect(0x602000, 4096, PROT_READ)     = 0
mprotect(0x7f80cf1f6000, 4096, PROT_READ) = 0
munmap(0x7f80cf1d3000, 134320)          = 0
set_tid_address(0x7f80cf1cc9d0)         = 31722
set_robust_list(0x7f80cf1cc9e0, 24)     = 0
rt_sigaction(SIGRTMIN, {0x7f80ccd25b50, [], SA_RESTORER|SA_SIGINFO, 0x7f80ccd31390}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {0x7f80ccd25be0, [], SA_RESTORER|SA_RESTART|SA_SIGINFO, 0x7f80ccd31390}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM64_INFINITY}) = 0
brk(0x11f2000)                          = 0x11f2000
socket(PF_LOCAL, SOCK_STREAM|SOCK_CLOEXEC, 0) = 3
connect(3, {sa_family=AF_LOCAL, sun_path=@"/tmp/.X11-unix/X0"}, 20) = 0
getpeername(3, {sa_family=AF_LOCAL, sun_path=@"/tmp/.X11-unix/X0"}, [20]) = 0
uname({sysname="Linux", nodename="erwanl-ThinkPad-W530", ...}) = 0
access("/home/erwanl/.Xauthority", R_OK) = 0
open("/home/erwanl/.Xauthority", O_RDONLY) = 4
fstat(4, {st_mode=S_IFREG|0600, st_size=65, ...}) = 0
read(4, "\1\0\0\24erwanl-ThinkPad-W530\0\0010\0\22MIT"..., 4096) = 65
read(4, "", 4096)                       = 0
close(4)                                = 0
getsockname(3, {sa_family=AF_LOCAL, NULL}, [2]) = 0
fcntl(3, F_GETFL)                       = 0x2 (flags O_RDWR)
fcntl(3, F_SETFL, O_RDWR|O_NONBLOCK)    = 0
fcntl(3, F_SETFD, FD_CLOEXEC)           = 0
poll([{fd=3, events=POLLIN|POLLOUT}], 1, -1) = 1 ([{fd=3, revents=POLLOUT}])
writev(3, [{"l\0\v\0\0\0\22\0\20\0\0\0", 12}, {"", 0}, {"MIT-MAGIC-COOKIE-1", 18}, {"\0\0", 2}, {"\275C\270p\230\301\234\264\265\177I\245,\326\6\215", 16}, {"", 0}], 6) = 48
recvfrom(3, 0x11d1330, 8, 0, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable)
poll([{fd=3, events=POLLIN}], 1, -1)    = 1 ([{fd=3, revents=POLLIN}])
recvfrom(3, "\1\0\v\0\0\0#\1", 8, 0, NULL, NULL) = 8
recvfrom(3, "`\35\264\0\0\0\0\5\377\377\37\0\0\1\0\0\24\0\377\377\1\7\0\0  \10\377\0\0\0\0"..., 1164, 0, NULL, NULL) = 1164
writev(3, [{"b\0\5\0\f\0\0\0BIG-REQUESTS", 20}], 1) = 20
recvmsg(3, {msg_name(0)=NULL, msg_iov(1)=[{"\1\0\1\0\0\0\0\0\1\205\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0", 4096}], msg_controllen=0, msg_flags=0}, 0) = 32
writev(3, [{"\205\0\1\0", 4}], 1)       = 4
recvmsg(3, {msg_name(0)=NULL, msg_iov(1)=[{"\1\0\2\0\0\0\0\0\377\377?\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0", 4096}], msg_controllen=0, msg_flags=0}, 0) = 32
recvmsg(3, 0x7fff08b75fd0, 0)           = -1 EAGAIN (Resource temporarily unavailable)
writev(3, [{"7\0\5\0\0\0\0\5\323\0\0\0\10\0\0\0\377\377\377\0\24\0\6\0\323\0\0\0\27\0\0\0"..., 44}, {NULL, 0}, {"", 0}], 3) = 44
recvmsg(3, {msg_name(0)=NULL, msg_iov(1)=[{"\1\10\4\0&\0\0\0\37\0\0\0\0\0\0\0\225\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 4096}], msg_controllen=0, msg_flags=0}, 0) = 184
recvmsg(3, 0x7fff08b76010, 0)           = -1 EAGAIN (Resource temporarily unavailable)
writev(3, [{"b\0\5\0\t\0\0\5", 8}, {"XKEYBOARD", 9}, {"\0\0\0", 3}], 3) = 20
recvmsg(3, {msg_name(0)=NULL, msg_iov(1)=[{"\1\0\5\0\0\0\0\0\1\207U\211\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0", 4096}], msg_controllen=0, msg_flags=0}, 0) = 32
recvmsg(3, 0x7fff08b75ee0, 0)           = -1 EAGAIN (Resource temporarily unavailable)
writev(3, [{"\207\0\2\0\1\0\0\0", 8}, {NULL, 0}, {"", 0}], 3) = 8
recvmsg(3, {msg_name(0)=NULL, msg_iov(1)=[{"\1\1\6\0\0\0\0\0\1\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0", 4096}], msg_controllen=0, msg_flags=0}, 0) = 32
recvmsg(3, 0x7fff08b75f90, 0)           = -1 EAGAIN (Resource temporarily unavailable)
open("/etc/libva.conf", O_RDONLY)       = -1 ENOENT (No such file or directory)
write(2, "libva info: VA-API version 0.99."..., 34libva info: VA-API version 0.99.0
) = 34
writev(3, [{"b\0\3\0\4\0\0\0", 8}, {"DRI2", 4}, {"", 0}], 3) = 12
recvmsg(3, {msg_name(0)=NULL, msg_iov(1)=[{"\1\0\7\0\0\0\0\0\1\231f\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0", 4096}], msg_controllen=0, msg_flags=0}, 0) = 32
recvmsg(3, 0x7fff08b75f50, 0)           = -1 EAGAIN (Resource temporarily unavailable)
writev(3, [{"b\0\10\0\27\0\0\0", 8}, {"Generic Event Extension", 23}, {"\0", 1}], 3) = 32
recvmsg(3, {msg_name(0)=NULL, msg_iov(1)=[{"\1\0\10\0\0\0\0\0\1\200\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0", 4096}], msg_controllen=0, msg_flags=0}, 0) = 32
recvmsg(3, 0x7fff08b75eb0, 0)           = -1 EAGAIN (Resource temporarily unavailable)
writev(3, [{"\200\0\2\0\1\0\0\0", 8}, {NULL, 0}, {"", 0}], 3) = 8
recvmsg(3, {msg_name(0)=NULL, msg_iov(1)=[{"\1\0\t\0\0\0\0\0\1\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0", 4096}], msg_controllen=0, msg_flags=0}, 0) = 32
recvmsg(3, 0x7fff08b75f70, 0)           = -1 EAGAIN (Resource temporarily unavailable)
writev(3, [{"\231\0\3\0\1\0\0\0\2\0\0\0", 12}, {NULL, 0}, {"", 0}], 3) = 12
recvmsg(3, {msg_name(0)=NULL, msg_iov(1)=[{"\1\0\n\0\0\0\0\0\1\0\0\0\3\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0", 4096}], msg_controllen=0, msg_flags=0}, 0) = 32
recvmsg(3, 0x7fff08b76020, 0)           = -1 EAGAIN (Resource temporarily unavailable)
writev(3, [{"\231\1\3\0\323\0\0\0\0\0\0\0", 12}, {NULL, 0}, {"", 0}], 3) = 12
recvmsg(3, {msg_name(0)=NULL, msg_iov(1)=[{"\1\0\v\0\5\0\0\0\4\0\0\0\16\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 4096}], msg_controllen=0, msg_flags=0}, 0) = 52
open("/dev/dri/card0", O_RDWR)          = 4
ioctl(4, DRM_IOCTL_GET_MAGIC, 0x7fff08b76200) = 0
writev(3, [{"\231\2\3\0\323\0\0\0\2\0\0\0", 12}, {NULL, 0}, {"", 0}], 3) = 12
recvmsg(3, {msg_name(0)=NULL, msg_iov(1)=[{"\1\0\f\0\0\0\0\0\1\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0", 4096}], msg_controllen=0, msg_flags=0}, 0) = 32
write(2, "libva info: va_getDriverName() r"..., 41libva info: va_getDriverName() returns 0
) = 41
geteuid()                               = 1000
getuid()                                = 1000
write(2, "libva info: User requested drive"..., 40libva info: User requested driver 'iHD'
) = 40
geteuid()                               = 1000
getuid()                                = 1000
write(2, "libva info: Trying to open /opt/"..., 70libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
) = 70
futex(0x7f80ce2560a8, FUTEX_WAKE_PRIVATE, 2147483647) = 0
open("/opt/intel/mediasdk/lib64/iHD_drv_video.so", O_RDONLY|O_CLOEXEC) = 5
read(5, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 Y\1\0\0\0\0\0"..., 832) = 832
fstat(5, {st_mode=S_IFREG|0755, st_size=37254904, ...}) = 0
mmap(NULL, 39378776, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 5, 0) = 0x7f80ca792000
mprotect(0x7f80ccace000, 2097152, PROT_NONE) = 0
mmap(0x7f80cccce000, 307200, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 5, 0x233c000) = 0x7f80cccce000
mmap(0x7f80ccd19000, 28504, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f80ccd19000
close(5)                                = 0
open("/usr/lib64/libdrm_intel.so.1", O_RDONLY|O_CLOEXEC) = 5
read(5, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\2201\0\0\0\0\0\0"..., 832) = 832
fstat(5, {st_mode=S_IFREG|0755, st_size=152152, ...}) = 0
mmap(NULL, 2247424, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 5, 0) = 0x7f80ca56d000
mprotect(0x7f80ca591000, 2097152, PROT_NONE) = 0
mmap(0x7f80ca791000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 5, 0x24000) = 0x7f80ca791000
close(5)                                = 0
open("/usr/lib64/libstdc++.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libstdc++.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 5
fstat(5, {st_mode=S_IFREG|0644, st_size=134320, ...}) = 0
mmap(NULL, 134320, PROT_READ, MAP_PRIVATE, 5, 0) = 0x7f80cf1d3000
close(5)                                = 0
open("/usr/lib/x86_64-linux-gnu/libstdc++.so.6", O_RDONLY|O_CLOEXEC) = 5
read(5, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \235\10\0\0\0\0\0"..., 832) = 832
fstat(5, {st_mode=S_IFREG|0644, st_size=1566440, ...}) = 0
mmap(NULL, 3675136, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 5, 0) = 0x7f80ca1eb000
mprotect(0x7f80ca35d000, 2097152, PROT_NONE) = 0
mmap(0x7f80ca55d000, 49152, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 5, 0x172000) = 0x7f80ca55d000
mmap(0x7f80ca569000, 13312, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f80ca569000
close(5)                                = 0
open("/usr/lib64/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/x86_64-linux-gnu/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = 5
read(5, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0p*\0\0\0\0\0\0"..., 832) = 832
fstat(5, {st_mode=S_IFREG|0644, st_size=89696, ...}) = 0
mmap(NULL, 2185488, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 5, 0) = 0x7f80c9fd5000
mprotect(0x7f80c9feb000, 2093056, PROT_NONE) = 0
mmap(0x7f80ca1ea000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 5, 0x15000) = 0x7f80ca1ea000
close(5)                                = 0
open("/usr/lib64/libpciaccess.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libpciaccess.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/lib/x86_64-linux-gnu/libpciaccess.so.0", O_RDONLY|O_CLOEXEC) = 5
read(5, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\320 \0\0\0\0\0\0"..., 832) = 832
fstat(5, {st_mode=S_IFREG|0644, st_size=39272, ...}) = 0
mmap(NULL, 2134416, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 5, 0) = 0x7f80c9dcb000
mprotect(0x7f80c9dd3000, 2097152, PROT_NONE) = 0
mmap(0x7f80c9fd3000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 5, 0x8000) = 0x7f80c9fd3000
close(5)                                = 0
open("/usr/lib64/libz.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libz.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/x86_64-linux-gnu/libz.so.1", O_RDONLY|O_CLOEXEC) = 5
read(5, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\360\35\0\0\0\0\0\0"..., 832) = 832
fstat(5, {st_mode=S_IFREG|0644, st_size=104824, ...}) = 0
mmap(NULL, 2199880, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 5, 0) = 0x7f80c9bb1000
mprotect(0x7f80c9bca000, 2093056, PROT_NONE) = 0
mmap(0x7f80c9dc9000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 5, 0x18000) = 0x7f80c9dc9000
close(5)                                = 0
mprotect(0x7f80c9dc9000, 4096, PROT_READ) = 0
mprotect(0x7f80c9fd3000, 4096, PROT_READ) = 0
mprotect(0x7f80ca55d000, 40960, PROT_READ) = 0
mprotect(0x7f80cccce000, 12288, PROT_READ) = 0
brk(0x1213000)                          = 0x1213000
futex(0x7f80ca56a1ac, FUTEX_WAKE_PRIVATE, 2147483647) = 0
futex(0x7f80ca56a1b8, FUTEX_WAKE_PRIVATE, 2147483647) = 0
write(2, "libva info: Found init function "..., 52libva info: Found init function __vaDriverInit_0_32
) = 52
open("/etc/igfx_registry.txt", O_RDONLY) = -1 ENOENT (No such file or directory)
ioctl(4, DRM_IOCTL_I915_GEM_GET_APERTURE, 0x7fff08b75f10) = 0
geteuid()                               = 1000
getuid()                                = 1000
ioctl(4, DRM_IOCTL_I915_GETPARAM or DRM_IOCTL_TEGRA_CLOSE_CHANNEL, 0x7fff08b75f20) = 0
ioctl(4, DRM_IOCTL_I915_GETPARAM or DRM_IOCTL_TEGRA_CLOSE_CHANNEL, 0x7fff08b75f20) = -1 EINVAL (Invalid argument)
open("/usr/lib64/libX11.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libX11.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
close(5)                                = 0
open("/usr/lib/x86_64-linux-gnu/libX11.so", O_RDONLY|O_CLOEXEC) = 5
read(5, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0p\210\1\0\0\0\0\0"..., 832) = 832
fstat(5, {st_mode=S_IFREG|0644, st_size=1285552, ...}) = 0
close(5)                                = 0
ioctl(4, DRM_IOCTL_I915_GETPARAM or DRM_IOCTL_TEGRA_CLOSE_CHANNEL, 0x7fff08b75ed0) = 0
write(2, "libva info: va_openDriver() retu"..., 38libva info: va_openDriver() returns 0
) = 38
fstat(1, {st_mode=S_IFCHR|0600, st_rdev=makedev(136, 18), ...}) = 0
write(1, "vainfo: VA-API version: 0.99 (li"..., 49vainfo: VA-API version: 0.99 (libva 1.67.0.pre1)
) = 49
write(1, "vainfo: Driver version: 16.5.1.5"..., 42vainfo: Driver version: 16.5.1.59511-ubit
) = 42
write(1, "vainfo: Supported profile and en"..., 42vainfo: Supported profile and entrypoints
) = 42
write(1, "      VAProfileH264ConstrainedBa"..., 56      VAProfileH264ConstrainedBaseline:    VAEntrypointVLD
) = 56
write(1, "      VAProfileH264ConstrainedBa"..., 61      VAProfileH264ConstrainedBaseline:    VAEntrypointEncSlice
) = 61
write(1, "      VAProfileH264ConstrainedBa"..., 61      VAProfileH264ConstrainedBaseline:    <unknown entrypoint>
) = 61
) = 61
write(1, "      VAProfileH264Main         "..., 56      VAProfileH264Main               :    VAEntrypointVLD
) = 56
write(1, "      VAProfileH264Main         "..., 61      VAProfileH264Main               :    VAEntrypointEncSlice
) = 61
write(1, "      VAProfileH264Main         "..., 61      VAProfileH264Main               :    <unknown entrypoint>
) = 61
) = 61
write(1, "      VAProfileH264High         "..., 56      VAProfileH264High               :    VAEntrypointVLD
) = 56
write(1, "      VAProfileH264High         "..., 61      VAProfileH264High               :    VAEntrypointEncSlice
) = 61
write(1, "      VAProfileH264High         "..., 61      VAProfileH264High               :    <unknown entrypoint>
) = 61
) = 61
write(1, "      VAProfileMPEG2Simple      "..., 61      VAProfileMPEG2Simple            :    VAEntrypointEncSlice
) = 61
write(1, "      VAProfileMPEG2Simple      "..., 56      VAProfileMPEG2Simple            :    VAEntrypointVLD
) = 56
write(1, "      VAProfileMPEG2Main        "..., 61      VAProfileMPEG2Main              :    VAEntrypointEncSlice
) = 61
write(1, "      VAProfileMPEG2Main        "..., 56      VAProfileMPEG2Main              :    VAEntrypointVLD
) = 56
write(1, "      VAProfileVC1Advanced      "..., 56      VAProfileVC1Advanced            :    VAEntrypointVLD
) = 56
write(1, "      VAProfileVC1Main          "..., 56      VAProfileVC1Main                :    VAEntrypointVLD
) = 56
write(1, "      VAProfileVC1Simple        "..., 56      VAProfileVC1Simple              :    VAEntrypointVLD
) = 56
write(1, "      VAProfileJPEGBaseline     "..., 56      VAProfileJPEGBaseline           :    VAEntrypointVLD
) = 56
write(1, "      VAProfileJPEGBaseline     "..., 63      VAProfileJPEGBaseline           :    VAEntrypointEncPicture
) = 63
write(1, "      VAProfileVP8Version0_3    "..., 61      VAProfileVP8Version0_3          :    VAEntrypointEncSlice
) = 61
write(1, "      VAProfileVP8Version0_3    "..., 56      VAProfileVP8Version0_3          :    VAEntrypointVLD
) = 56
write(1, "      VAProfileVP8Version0_3    "..., 61      VAProfileVP8Version0_3          :    <unknown entrypoint>
) = 61
write(1, "      VAProfileVP9Profile0      "..., 61      VAProfileVP9Profile0            :    <unknown entrypoint>
) = 61
write(1, "      <unknown profile>         "..., 62      <unknown profile>               :    VAEntrypointVideoProc
) = 62
write(1, "      VAProfileNone             "..., 62      VAProfileNone                   :    VAEntrypointVideoProc
) = 62
write(1, "      VAProfileNone             "..., 61      VAProfileNone                   :    <unknown entrypoint>
) = 61
--- SIGSEGV {si_signo=SIGSEGV, si_code=SI_KERNEL, si_addr=0} ---
+++ killed by SIGSEGV (core dumped) +++
Loc_N_Intel
Would you like to post your Media Server question in the Media forum (https://software.intel.com/en-us/forums/intel-media-sdk) instead? This forum is used for Intel Many Integrated Core Architecture questions only.
Song__Gibeom
Is this problem has been solved?
I have this problem too. T^T
Please help me
