Software Archive
Read-only legacy content
17060 Discussions
crosswalk problem
paolo_c_
i have a problem with crosswalk building.
Every app i building in my phone alert "Il programma xxx è stato arrestato" (the xxxx program has been stopped)
I work with 2323 version and i have problem building also HTML5 + Cordova esample program.
In emulator work, in preview work in phone doesn't work.
can I help me?
thanks
PaulF_IntelCorp
Can you build and run the HTML5+Cordova template app as a Crosswalk app? Does that work?
Can you run your app on your device using the Debug tab? That uses Crosswalk.
When you install the built Crosswalk app onto your device are you installing the x86 or the ARM version? Most devices (especially phones) are ARM devices. Use the CPU-Z application to see what your device architecture is. If the architecture says "Intel" you have an x86 device, otherwise you have an ARM device.
