Software Archive
Read-only legacy content
17060 Discussions
Release 2248 continually freezes
Evert_G_
Since I started to use the new release, I keep having problems.
Specifically when i do a number of changes to css, after some time it just slows down until it freezes.
Seems like a memory problem here, although I still have enough free mem.
But maybe it also has something to do with my instable internet connection, like when the xdk were uploading changes continually.
I do see a big spike in tcp connections, which peters out over time.
Restarting the xdk helps for a short while, as does the restart of the os (w7).
regards,
Evert
Brandon_K_Intel
How are you building your application? Are you using App Designer or are you just editing the css by hand?
Evert_G_
I am using the App Designer
Brandon_K_Intel
Which framework are you using inside of App Designer?
Evert_G_
I am using app framework 2.1
PaulF_IntelCorp
Have you tried this with the latest release: v2323?
