Software Archive
Read-only legacy content
17060 Discussions
disable vectorization
Jianbin_F_
Hi, I have a question on MIC. That is, when using -O2 (or further -O3), the compiler will vectorize the code automatedly. However, when we further add the -no-vec option, the compiler will not vectorize the code, right? But when looking into the assembly code (*.s), I found that there are still a lot of vector instrustructions there. Then what are the differences between using and not using the vector option? The compiler will vectorize the code anyway?
Jianbin
TimP
The short story is that scalar floating point is done by using one slot in the mm512 registers, and the basic instruction name is unchanged.
Kevin_D_Intel
The use of vector instructions is a by-product of the architecture. I expect you are using -mmic. The compiler honors -no-vec when compiling for native. Add a -vec-report option (e.g. -vec-report6) to verify code is vectorized at -O2 or -O3 and then use that same report option with -no-vec to confirm it disabled vectorization.
Here’s some additional resources:
Intel® Xeon Phi™ Coprocessor Developer Zone (On the Overview tab, look for the link to the Intel® Xeon Phi™ Coprocessor Instruction Set Architecture Reference Manual)
Intel® Xeon Phi™ Coprocessor Vector Microarchitecture
Programming and Compiling for Intel® Many Integrated Core Architecture
Jianbin_F_
OK, but when I measure the vectorization intensity (VPU_ELEMENTS_ACTIVE/VPU_INSTRUCTIONS_EXECUTED), I found that the VI number is around 4 for GEMM (with -no-vec, -mmic, and -O3), rather than 1. Therefore, I do not aggree with the opintion that the instruction uses only one slot out of eight. I wonder whether you have any idea of it?
Jianbin_F_
You are right that the use of vector instructions is a by-product. But what do you mean by the compiler will honor the -no-vec option? In my opinion, using -no-vec means that only one of the 8 or 16 lanes should be used (as TimP has mentioned). But my experimental results show that the vectorization intensity on GEMM (with -no-vec, -mmic, and -O3) is around 4, rather than 1. Indeed, the -vec-report message does not show any vectorization information, but how can you explain the vectorization instruction was using more than one lane/slot of the VPU?
Jianbin
Kevin_D_Intel
-no-vec disables auto-vectorization only. Development confirmed this and also indicated the option does not prevent scalar code from using vector instructions in any way it likes, and even on Xeons, that it does not prevent scalar code from using packed instructions.
Jianbin_F_
Hi Kevin, thank you for your answer.
