Software Archive
Read-only legacy content
error #10310: Failed to enable trusted storage check for licensing: WARNING: Enable Trusted Storage failed
Dan_L_1
I am running an evaluation version of Intel Visual Fortran compiler (Parallel Studio XE 2015) on Windows8.1.
I can run a hello world f90 program with MS Visual Studio 2010. However When I build a large project using Intel Visual Fortran compiler, I got the follow error message:
Package 'Intel.Fortran.IFLangService.IFLangServicePackage, IFLangService, Version=15.0.0.0, Culture=neutral, PublicKeyToken=null' failed to load.
ifort: error #10310: Failed to enable trusted storage check for licensing: WARNING: Enable Trusted Storage failed (flexnet error code 20). Trusted Storage based license could not be supported
I have seen various posts suggesting the error is due to the lack of a license file. Please help. Thank you!
James_T_Intel
Hi Dan,
I will send your license file to you via private message.
Sincerely,
James Tullos
Technical Consulting Engineer
Intel® Cluster Tools
Dan_L_1
I would like to know have you sent me the license yet? Thank you?
James_T_Intel
Yes, you have a private message with both of your evaluation licenses.
Dan_L_1
Thank you very much! I would like to know why I need two licenses? Based on https://software.intel.com/en-us/articles/evaluation-license-error-10310-failed-to-enable-trusted-storage-check-for-licensing, I only need one license file?
James_T_Intel
I sent two license files because you signed up for two evaluations.
Dan_L_1
I am sorry that I am not sure why I post my comments so many times.
Dan_L_1
Oh, sorry. I guess I can just use one of them right?
James_T_Intel
No worries, I cleaned up the excess replies.
James_T_Intel
Use the one appropriate to the product you are installing.  Both of your licenses should cover the Fortran compiler.  But if you intended to only get one evaluation, I would recommend using the one with last character in the filename 9.  This one is for the full suite of tools.
Dan_L_1
Thank you very much for your help!!
Prateek_S_
I have the same problem with my evaluation version. Can you please tell me how do I get my licence file? I am running it on windows 7
Hubert_H_Intel
Plese let me know your email address (via "Send Author A Message") under which you registered your eval license.
Hubert.
K_M_
Hello, I am having the same issue. Can you please email me my license file for the trial?
Thank you!
Ken
Asfandyar_A_
Hi
I am also having the same problem
can you please email me the lic file.
Asfandyar
Sid_T_
Hello
I have exactly the same error on Linux platform. See below:
root@orions:/opt/intel/flexlm> ./chklic
License file = </usr/local/flexlm/licenses/license.dat>
License file = <Trusted Storage>
WARNING: Enable Trusted Storage failed (flexnet error code 2). Trusted Storage based license could not be supported
What can I do please ?
When I try to execute an intel command, I get the following error:
root@orions:/opt/intel/flexlm> ../bin/icc
Error: A license for CCompL is not available now (-97,121).
A connection to the license server could not be made.  You should
make sure that your license daemon process is running: both an
lmgrd process and an INTEL process should be running
if your license limits you to a specified number of licenses in use
at a time.  Also, check to see if the wrong port@host or the wrong
license file is being used, or if the port or hostname in the license
file has changed.
License file(s) used were (in this order):
    1.  Trusted Storage
**  2.  /opt/intel/composer_xe_2015.3.187/bin/intel64/../../Licenses
**  3.  /root/Licenses
**  4.  /opt/intel/licenses/l_3PS6BBT4.lic
**  5.  /Users/Shared/Library/Application Support/Intel/Licenses
**  6.  /opt/intel/composer_xe_2015.3.187/bin/intel64/*.lic
Please visit http://software.intel.com/sites/support/ if you require technical assistance.
icc: error #10052: could not checkout FLEXlm license
Any help ?
Thank you
