Software Archive
Read-only legacy content
error compiling app to iOS
Marcondes__Marcos
Im doing my first compilation to iOS and Im getting error and Intel XDK is saying it is wrong but no idea what is :(((
Please check log and please let me know what I need to do
Thanks in advance !
Marcos
PaulF_IntelCorp
Marcos -- this looks like a certificate problem, or an App ID problem (or the two do not match).
PaulF_IntelCorp
You probably haven't submitted any Apple developer certificiates to the build system. Without those it cannot build you an iOS app. This is an Apple tools restriction, there is no way for the XDK to get around this. See this portion of your build log:
Check dependencies
Code Sign error: Provisioning profile does not match bundle identifier: The provisioning profile specified in your build settings (“ConteudoAnimal”) has an AppID of “ConteudoAnimal” which does not match your bundle identifier “ConteudoAnimal (J742AZDFK4.ConteudoAnimal)”.
CodeSign error: code signing is required for product type 'Application' in SDK 'iOS 8.0'
** BUILD FAILED **
p.s. In the future, please attach build logs as text files, to not paste them into your post, it makes for very difficult support of your questions.
Marcondes__Marcos
First sorry, I updated topic as you suggested to add log into file
I did 2 certificates ... first done but intel xdk and put that file into apple site and got another .... the 1a and 1b and place both files
I put inside of www directory both files : distribution.CertificateSigningRequest.csr and ConteudoAnimal.mobileprovision
Is it not enough ?
What I need more ?
PaulF_IntelCorp
Did you follow this tutorial? https://software.intel.com/en-us/xdk/docs/building-cordova-ios-apps-intel-xdk
You need to submit the cert file to the build system (see tutorial) and then you specify the mobileprovision file in your build settings (see the tutorial).
Marcondes__Marcos
Hi Paul,
Nope ... I used another tutorial from Apple website to create the certificates
Im checking your link and proceed as requested and I feedback here
Thanks in advance !
Marcos
Marcondes__Marcos
I followed the tutorial and created files as shown but still failing :(((
I want to send the created files but upload tool does not support it :(( Even if I put it into zip file
I feel the problem I put 2 certificated ... ad hoc and production ... same file like picture attached
I tried so many times to remove it and couldnt
How to proceed ?
Marcos
PaulF_IntelCorp
Marcos, I think the problem is that you have not submitted the certificate files to the build system from the build page. I'm not talking about the mobile provision files, what you have done for those looks fine. You ALSO need to submit your apple developer certificate to the build system. See the first part of that tutorial I gave you.
Marcondes__Marcos
Paul,
I solve the problem
It was I did not tick push notication option during creating certificates
After this I could compile and create the file.ipa to upload to appstore
Now I faced another wall to apple ... I need to upload to appstore ... using xcode or application upload which both does not work on windows kkk
I will open another ticket to discuss this ... how can I upload apple app using windows only ....
OMG ... Apple sucks kkk
Thanks for patience with me
God bless you all
PaulF_IntelCorp
There are services available or you will have to find a friend or colleague that has a Mac to perform that last step. Sorry, there's not much we can do about that, it's another Apple restriction. :(
Marcondes__Marcos
Heya
I just sent my app .... crossing finger all set and be avaliable on itunes ASAP :-)
My solution was install Mac OS X Virtual Machine on my Windows notebook.
All set ... downloaded the Application Loader and sent the file to itunes !!!
Thanks for all help to solve the issues above !!!
Marcondes__Marcos
Now I am getting another erro like file
What is wrong ?
thanks in advance !
PaulF_IntelCorp
Marcondes__Marcos
Thanks a lot .... seems certificate error ... for god power it got invalid ...I didnt change anything from last good compilation and this one
I recreate the certification and worked properly
Magic just Apple can provide kkkk
Well ... problem is now with intel help resolved !
thanks a lot team
Marcos
