Software Archive
Read-only legacy content
error message
Mostapha_B_
Using fortran compiler, I received the following message:
Ifort:error #10310: failed to enable trusted storage check for licensing: Warning : Enable Trusted Storage Failed <Flexnet Error Code 20>  Trusted Storage Based License could not be supported.
Any help to overcome this issue is much appreciated
Hubert_H_Intel
Mostapha,
That means that you do not have a valid license installed actually. All I see under your registrations are expired Evaluation licenes which no longer work. Or do you have a product license which hasn't been installed/registered successfully yet?
Regards, Hubert.
