Software Archive
Read-only legacy content
17060 Discussions
error when using icpc to compile a program which uses coi library
songlinhai
hi,
   I got the following error, when use icpc to compile a program which is using coi library.
ld: skipping incompatible /opt/intel/mic/coi/device-linux-debug/lib/libcoi_device.so when searching for -lcoi_device
ld: cannot find -lcoi_device
The command I use is
icpc -L/opt/intel/mic/coi/device-linux-debug/lib -I /opt/intel/mic/coi/include -I ../../../include -lcoi_device -lpthread -rdynamic -Wl,--enable-new-dtags -g -O0 -D_DEBUG -openmp -DTHREADS=200 -openmp-report -o debug/kmeans-seq-sink kmeans-seq-sink.c
    any hints or suggestions?
    thanks a lot!
Kevin_D_Intel
To use icpc for the sink-side (or device side) compilation, add: -mmic
That will yield using the compatible compiler and linker to the libs you referenced. Without this option you are mixing the host-side compiler/linker with device-side libraries which are not compatible.
