Software Archive
Read-only legacy content
evaluation license file
George_S_
Looking for an Intel engineer to mail us our evaluation license file.
We need this file to resolve the following Windows C++ compiler error:
icl: : error #10310: Failed to enable trusted storage check for licensing: WARNING: Enable Trusted Storage failed (flexnet error code 20). Trusted Storage based license could not be supported
Feilong_H_Intel
Hi George,
I sent the license file to you via email.  Please refer to this article and copy it to your machine.
George_S_
Thanks!
Abhishek_S_5
Hi
Please send the evaluation licence file for Intel® Parallel Studio XE 2015 for Windows (64 bit application).
Currently facing the below mentioned issue:
Evaluation licensed customers cannot compile x64 applications.  Compiling 32bit applications works as expected, however.  x64 builds results in error similar to:
------ Build started: Project: OptimizerInterface1, Configuration: Release x64 ------
1>Compiling with Intel(R) Visual Fortran Compiler XE 15.0.0.108 [Intel(R) 64]...
1>foo.f90
1>ifort: error #10310: Failed to enable trusted storage check for licensing: WARNING: Enable Trusted Storage failed (flexnet error code 20). Trusted Storage based license could not be supported
1>Fooproject - 3 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Abhishek
Feilong_H_Intel
Hi Abhishek,
Please send me a message by clicking Send Author A Message.  Let me know your email or your serial number.  I'll send license file to you.
