Software Archive
Read-only legacy content
evaluation license file
Jeffrey_M_
Looking for the evaluation license for Parallel Studio XE 2015.
regards,
jeffrey
Evaluation license error #10310: Failed to enable trusted storage check for licensing
Reference Number : DPD200361654
Version :
  • Intel® Parallel Studio XE 2015 for Windows, (Composer Edition, Professional Edition, Cluster Edition) initial release
Operating System :
Windows
Problem Description :
Evaluation licensed customers cannot compile x64 applications.  Compiling 32bit applications works as expected, however.  x64 builds results in error similar to:
------ Build started: Project: OptimizerInterface1, Configuration: Release x64 ------
1>Compiling with Intel(R) Visual Fortran Compiler XE 15.0.0.108 [Intel(R) 64]...
1>foo.f90
1>ifort: error #10310: Failed to enable trusted storage check for licensing: WARNING: Enable Trusted Storage failed (flexnet error code 20). Trusted Storage based license could not be supported
1>Fooproject - 3 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Resolution Status :
9/30/2014: This error is under investigation.
Workaround:
By installing your evaluation license file on your system, and running the installer again (repair mode) will fix this issue.
  1. To get an email with your license file ( .lic extension ), go to our Startup Support User Forum and ask an Intel Engineer to mail you your evaluation license file.
QIAOMIN_Q_
Hello Jeffrey,
I have sent you the license file, please let me konw if that works for you now.
Thank you.
QIAOMIN.Q
Intel Developer Support
