Software Archive
Read-only legacy content
17060 Discussions
face expressions is always null in javascript application
Kim_D_
When testing the javascript API I noticed that the face expressions object is always null. I have "configs.expressionProperties.isEnabled" set to true.
I noticed that the face_tracking.html example also does not give any expression information when turned on. Landmarks, pose, detection work well.
I have tested both the face_tracking and face_tracking.cs example applications on my setup and there I do get the expression data.
Did I forget to activate something else? Or is it simply not implemented in the javascript API? It would be just a matter of forwarding the data no?
Thanks for any help.
DMaio
It looks like it is a missing feature. I still didn't find a way to enable this.
I've already posted a similar question : https://software.intel.com/en-us/forums/topic/537168
Kim_D_
I see. That's a bit annoying.
Whether it's a bug or a currently missing feature, I think it should be quite easy for Intel to add/fix as I think the webserver is just an application getting this data and forwarding it over websockets. Please correct me if this is not the case.
Could of course write a second web server that does this for the expression data as is already suggested in the thread you link. Just a bit annoying as it feels like 'lost' work/time.
Thanks for the help!
Arthur_T_1
Hi
Was any of you successful with this in the end?
