Software Archive
Read-only legacy content
17060 Discussions
fail to find license
meng-sing
when I use ifort to compile my fortran code, I got the following errors
Error: A license for (Comp-FM) could not be found.
License file(s) used were (in this order):
    1.  Trusted Storage
**  2.  /usr/bin/ifort-16.0-base/bin/intel64/../../Licenses
**  3.  /Users/mliou1/Licenses
**  4.  /opt/intel/licenses
**  5.  /Users/Shared/Library/Application Support/Intel/Licenses/m_H3TGFH7R.lic
**  6.  /usr/bin/ifort-16.0-base/bin/intel64/*.lic
AND
error #10052: could not checkout FLEXlm license
Light_Intel
Thank you for contacting Intel Support.
Looking at your licenses you have 5 expired EVAL licenses, 3 older COM licenses and 2 current EVAL licenses. I am suspecting the ifort is encountering an expired license. Are you using the EVAL compiler or the COM compiler? Please go to all the locations indicated above and delete old license files from those locations. This should resolve the issue.
Noga
Intel Developer Support
meng-sing
How do I find the locations of these licenses? I thought that the EVAL compiler I just downloaded would take the place of old ones, apparently it is not true. Then I don’t know which one the system takes for compilation, how do I find it out?
Light_Intel
Evaluation licenses are being placed in:
    1.  Trusted Storage
Regular licenses are placed in the other locations specified above.
When trying to install please use the SN option and enter the SN that was sent to you with your evaluation email.
Noga
