Software Archive
Read-only legacy content
17060 Discussions
force landscape orientation
sam_w_1
What is the best way to force landscape orientation?  (I am developing for microsoft surface )
It looks like the following is deprecated - what is the current method?
intel.xdk.device.setRotateOrientation("portrait");
Anusha_M_Intel1
Please refer to our orientation sample that ships with the XDK.
New Projects -> Samples & Demos -> HTML5 + Cordova -> Orientation Sample
You can also refer to the Cordova Orientation plugin that uses the device's compass to sense the direction the device is pointed: https://github.com/apache/cordova-plugin-device-orientation
Chris_P_Intel
If you simply want your app to always be one orientation or another, use the Build setting called "Orientation" in the Projects pane
Anusha_M_Intel1
Good point. Since you say you only need landscape orientation and do not need the UI to change according to orientation detected, Chris's suggestion should work.
