HI there,
I was playing around with a simple offload code and I discovered that the program was keep crashing claiming there is no offload entry. (see source attached).
[alin@phinally:~/lavello/XeonPhi/hello/fortran]: ./semicolon.MIX
x = 100
x = 101 i = 101
offload error: cannot find offload entry __offload_entry_semicolon_F90_31MAIN__
x = 101 i = 101
offload status: 4
offload device: 0
offload data (sent in B): 4
offload data (received in B): 0
after removing the semicolon on line 12 everthing seems to run as expected
x = 100
x = 101 i = 101
x = 103 i = 103
offload status: 0
offload device: 0
offload data (received in B): 8
regards,
Alin
Hi Alin. What an interesting case. Sorry for the trouble that must have caused. I reproduced this, reported it to the Fortran Front-end team (see internal tracking below), and will update the post about a fix as I learn it.
(Internal tracking id: DPD200247866)
Thank you Kevin! Indeed was tricky one to figure out, however gave me the chance to read in detail the offload part of the manual.
regards,
Alin
