Software Archive
Read-only legacy content
17060 Discussions
forwarding technique
Jianbin_F_
Hi, I have a question on the pipeline of Xeon Phi. That is, does the pipeline of Xeon Phi support forwarding technique? If it does, there should not be any stalls for the RAW instructions (suppose the instructions access register only and no memory access).
(1) ADD R1, R2, R3    // write the result into register R1
(2) MUL R5, R1, R4    // read the content of register R1
In theory, if the pipeline suupports the forwarding technique, there should not be any stalls between instruction (1) and instruction (2).
Jianbin
Sumedh_N_Intel
The Intel Xeon Phi coprocessor vector micorarchitecture does use forwarding. You can read more about the microarchitecture in the following article.
http://software.intel.com/en-us/articles/intel-xeon-phi-coprocessor-vector-microarchitecture
