Software Archive
Read-only legacy content
17060 Discussions
generate pem file - sending push notifications
Emanuel_H_
hello, i just searched a lot but nothing will work.
i wanna send push notifications on ios... server-side - i need the *.pem file - but i cant generate this.
aps.cer is already created but i cant convert it. i found something about openssl but dont know how to... :-/
maybe you can help me.
Emanuel_H_
this one helped me:
# Make sure terminal refers your correct certificate path.
$ cd ~/Desktop/
# Ask system administrator to open if its not connected
$ telnet gateway.sandbox.push.apple.com 2195
Trying 17.110.227.35...
Connected to gateway.sandbox.push-apple.com.akadns.net.
Escape character is '^]'.
# Convert .cer to .pem
$ openssl x509 -in aps_development.cer -inform der -out PushCert.pem
# Convert .p12 to .pem. Enter your pass pharse which is the same pwd that you have given while creating the .p12 certificate. PEM pass phrase also same as .p12 cert.
$ openssl pkcs12 -nocerts -out PushKey1.pem -in pushkey.p12
Enter Import Password:
MAC verified OK
Enter PEM pass phrase:
Verifying - Enter PEM pass phrase:
# To remove passpharse for the key to access globally. This only solved my stream_socket_client() & certificate capath warnings.
$ openssl rsa -in PushKey1.pem -out PushKey1_Rmv.pem
Enter pass phrase for PushChatKey1.pem:
writing RSA key
# To join the two .pem file into one file:
$ cat PushCert.pem PushKey1_Rmv.pem > ApnsDev.pem
Shahab_L_Intel
Hi Emanuel,
Unfortunately we cannot provide support on this, you can refer to pem's documentation or post on a forum like stack overflow.
Good luck,
Shahab
Emanuel_H_
this one helped me:
$ cd ~/Desktop/
MAC verified OK
writing RSA key
