Software Archive
Read-only legacy content
google login
Alberto_G_
Hi everyone,
I'm developing an app that requires login via google. I followed the tutorial on this page (https://software.intel.com/en-us/html5/articles/oauth2-with-intelxdk-cordova-html5#comment-1809957), but  was not able to configure all the parameters correctly. For example I do not understand which value must have parameter Auth_url, or the possible values of scope.
Can you help me?
Elroy_A_Intel
Did you try the example at https://github.com/krisrak/jquery-cordova-oauth2 which the "Using Oauth 2.0 login for HTML5 apps" article is based on?
Alberto_G_
hi,
thank for your answer.
Yes, i alredy try the example. I donwloaded the zip file and run it in intel xdk, but when i test the application on device i get this error
and this is the code i set
function oauth2_login() {
    $.oauth2({
        auth_url: 'https://accounts.google.com/o/oauth2/auth',           // required
        response_type: 'token',      // required - "code"/"token"
        client_id: '****.apps.googleusercontent.com',          // required
        redirect_uri: 'http://localhost',       // required - some dummy url
        other_params: {scope:'profile'}        // optional params object for scope, state, display...
    }, function(token, response){
        // do something with token or response
        $("#logs").append("<p class='success'><b>access_token: </b>"+token+"</p>");
        $("#logs").append("<p class='success'><b>response: </b>"+JSON.stringify(response)+"</p>");
    }, function(error, response){
        // do something with error object
        $("#logs").append("<p class='error'><b>error: </b>"+JSON.stringify(error)+"</p>");
        $("#logs").append("<p class='error'><b>response: </b>"+JSON.stringify(response)+"</p>");
Abhigyan_G_
I need some help regarding google login in cordova intel xdk, I am able to call google login page but after login not going to my project,Its going somewhere else
PaulF_IntelCorp
Please research this issue on StackOverflow under the Cordova link. The XDK creates standard Cordova apps and StackOverflow and the many blogs regarding Cordova apps are your best resource for resolving this question. We do not providing general programming support in this forum, only product-specific support.
