Software Archive
Read-only legacy content
gsl library optimization error
JJK
New Contributor III
Hi all,
as a follow up to my previous post on the gsl library coredumping on the Xeon Phi there is good news and bad news.
The good news is: with icc v15 the coredumps are gone
The bad news is: there are other vectorization errors that seem to occur only when -mmic is used.
Consider the following program (distilled from the gsl-1.16 source code):
#include <stdio.h>
struct gsl_block_char_struct
  size_t size;
  char *data;
typedef struct gsl_block_char_struct gsl_block_char;
typedef struct
  size_t size1;
  size_t size2;
  size_t tda;
  char * data;
  gsl_block_char * block;
  int owner;
} gsl_matrix_char;
gsl_block_char *
gsl_block_char_alloc (const size_t n)
  gsl_block_char * b;
  b = (gsl_block_char *) malloc (sizeof (gsl_block_char));
  b->data = (char *) calloc (1, 1 * n * sizeof (char));
  b->size = n;
  return b;
gsl_matrix_char *
gsl_matrix_char_alloc (const size_t n1, const size_t n2)
  gsl_matrix_char * m;
  m = (gsl_matrix_char *) malloc (sizeof (gsl_matrix_char));
  block = gsl_block_char_alloc (n1 * n2) ;
  m->data = block->data;
  m->size1 = n1;
  m->size2 = n2;
  m->tda = n2;
  m->block = block;
  m->owner = 1;
  return m;
gsl_matrix_char_get(const gsl_matrix_char * m, const size_t i, const size_t j)
  return m->data[i * m->tda + j] ;
void
gsl_matrix_char_set(gsl_matrix_char * m, const size_t i, const size_t j, const char x)
  m->data[i * m->tda + j] = x ;
void
gsl_matrix_char_minmax (const gsl_matrix_char * m,
                               char * min_out,
                               char * max_out)
  const size_t M = m->size1;
  const size_t N = m->size2;
  const size_t tda = m->tda;
  char max = m->data[0 * tda + 0];
  char min = m->data[0 * tda + 0];
  size_t i, j;
//  #pragma novector
  for (i = 0; i < M; i++)
//      #pragma novector
      for (j = 0; j < N; j++)
          char x = m->data[i * tda + j];
          if (x < min)
              min = x;
          if (x > max)
              max = x;
  *min_out = min;
  *max_out = max;
void
test_char_func (const size_t M, const size_t N)
  size_t i, j;
  size_t k = 0;
  char min, max;
  gsl_matrix_char * m = gsl_matrix_char_alloc (M, N);
      k++;
      gsl_matrix_char_set (m, i, j, (char) k);
  char exp_max = gsl_matrix_char_get (m, 0, 0);
  char exp_min = gsl_matrix_char_get (m, 0, 0);
      char k = gsl_matrix_char_get (m, i, j);
      if (k > exp_max) {
        exp_max =  gsl_matrix_char_get (m, i, j);
      if (k < exp_min) {
        exp_min =  gsl_matrix_char_get (m, i, j);
  gsl_matrix_char_minmax (m, &min, &max);
  printf("exp_max = %02X max = %02X\n", exp_max, max);
  printf("exp_min = %02X min = %02X\n", exp_min, min);
  if (max != exp_max) fprintf(stderr, "gsl_matrix_char_minmax returns incorrect maximum value\n");
  if (min != exp_min) fprintf(stderr, "gsl_matrix_char_minmax returns incorrect minimum value\n");
int
main (void)
  size_t M = 53;
  size_t N = 107;
  test_char_func (M, N);
This code compiles without a warning using
icc -O2 -mmic -Wall -Wuninitialized -g -o mytest mytest.c
yet when it runs it produces a warning
$ ssh mic0 $PWD/mytest
exp_max = 7F max = 27
exp_min = FFFFFF80 min = 00
Remove the '-mmic' and rerun on the host CPU and the code runs just fine.
If I uncomment the #pragma vector lines the code also runs fine on the Xeon Phi.
Kevin_D_Intel
Hi Jan,
Thank you for the convenient test case!   I reproduced the behavior described using both the 14.0 and 15.0 compilers. The expected results occur at -O1 or at -O2 but with -O2 only when the novector directive is active for the inner loop. The other compiler options are not at play.
I reported this to Development (see Internal tracking id below) for some further analysis and will keep you updated on their findings.
(Internal tracking id: DPD200360578)
(Resolution Update on 11/17/2014): This defect is fixed in the Intel® Parallel Studio XE 2015 Update 1 release (2015.0.133 - Linux)
Kevin_D_Intel
Development confirmed this is a defect related to an incorrect conversion generated using an unsigned data type instead of a signed data type. To work around (as you found), the novector can be used although they thought using an unsigned char or int instead of signed char might also. I tried those and int seemed to work but the novector is probably best/easiest.
I will keep you updated on the availability of a fix in a future IPS XE 2015 (15.0 compiler) release.
JJK
New Contributor III
Hi Kevin,
I can live with that without any issues - I think I'll create a patch for the gsl lib to compile and test it for the Xeon Phi ; that patch would include the #pragma line in it plus some minor changes to the gsl libtool code so that the tests are actually run on the Xeon Phi.
AFAIAC this ticket can be closed.
Kevin_D_Intel
Ok, sounds good Jan.
Kevin_D_Intel
This defect is fixed in the Intel® Parallel Studio XE 2015 Update 1 release (Version 15.0.1.133 Build 20141023 - Linux) now available from our Intel® Registration Center.
