Software Archive
Read-only legacy content
17061 Discussions
how can I solve this problem with long time uploading all the day?3357
lele_h_
Hi,all!
  I use the  xdk (version 3357) caught so many problems  today and not solved.!  I try it all the day and have no ways !
 1.   I  use a  proxy to connect my network.  it build faild with something like
        ERROR (-9) from "client:upload-manager": Error in uploading project files: : Error in uploading project files: : Error in uploading project files: : unable to verify the first certificate Error at new ComponentError (F:\software\XDK\xdk\core-modules\public\component-error.js:17:1122) at makeError (file:///F:/software/XDK/xdk/components/client/upload-manager/upload-manager.js:17:170) at getComponentError (file:///F:/software/XDK/xdk/components/client/upload-manager/upload-manager.js:17:265) at file:///F:/software/XDK/xdk/components/client/upload-manager/upload-manager.js:17:11448 at _rejected (F:\software\XDK\xdk\node_modules\q\q.js:844:24) at F:\software\XDK\xdk\node_modules\q\q.js:870:30 at Promise.when (F:\software\XDK\xdk\node_modules\q\q.js:1122:31) at Promise.promise.promiseDispatch
   err
2 when i turn off the proxy and restart xdk and build it to android ,it will run all day with uploading project files,i have wait more than 3-4 hours and also try it again and again,my project is small!
image: Image
Elroy_A_Intel
This seems to be related to an issue with your installer. Can you uninstall Intel XDK, reboot your machine and reinstall Intel XDK? This should address your issue.
Giovanni_B_1
Hello, I have a similar problem with XDK 3400.
The error is "unable to upload the project files" and inside log: "tunneling socket could not be established".
Fortunately I had a copy of version 3240 installed: everything works fine with the older version.
Pamela_H_Intel
Iele - did you try reinstalling 3357? Or try upgrading to 3400?
Giovanni - I am glad you could continue your work with a previous version. Since 3400 has been out for a week and we haven't heard of others having this issue with 3400, I would guess that there was a problem with installation, and a retry might fix it.
Avi_S_1
I have version 3400 and appear to have the same issue. This is through a work proxxy.
PaulF_IntelCorp
Avi -- does it work if you try from your home network?
PaulF_IntelCorp
We've alerted engineering to see if we can figure out what's behind this issue.
PaulF_IntelCorp
Regarding the upload problems, engineering suggests trying the following:
  • in the root of your project directory create a file name intelxdk.upload.request.txt
  • inside that file add a single line with the number 120
  • exit and restart the XDK
The presence of that file, in the root of your app’s project directory, causes version 3400 of the XDK to use an alternate upload method for all files that are less than 120MB in size. I’ve attached an example of such a file. It should be located in the same place where you find the various intelxdk.config.*.xml files inside your project directory (at the root of your project directory).
Please let us know if this fixes this upload problem.
Rob_H_2
I placed that file into my directory and I am still getting the same error.
PaulF_IntelCorp
Rob -- engineering suggests doing the following, in order to get more detailed information from node-webkit, which is what the XDK actually runs on top of (it has a private copy of nw as part of it's installation):
1.  Go into your users (theirlogin) AppData\Local\Intel\Xdk\bin folder
2.  to get there (in Windows) type %localappdata% in the filepath box
3.  Edit the file named xdk.cmd (make a copy first)
4.  Find and replace these lines in xdk.cmd
> call :format "%pwd%..xdk" %%xd
> "%nw%" "%xd%"
 with
> "%nw%" "%xd%" --enable-logging --v=1
That is add space dash-dash-enable-dash-logging space dash-dash-vee-equals-one
5.  Run xdk.cmd to launch the XDK
6. Get to the point where clicking the build button fails
7. Copy the debug.log file and send it to us PRIVATELY (it may contain sensitive info)
8. Revert back to the original xdk.cmd
I'll send you a private message that you can reply to in order to send back the resulting log file. Note that this is a four day holiday weekend, so there will not be any action taken on this until we return to work on Wednesday of next week.
PaulF_IntelCorp
Also, another request is to use openssl to see the certificate chains being returned by the server. This will help to understand if there is a network interception happening, which might be interfering with the certificate authentication process. If you do not have openssl installed on your system you'll need to download and install it to perform the following test.
From a command prompt:
> openssl s_client -showcerts -connect appcenter.html5tools-software.intel.com:443
 (type ^C after the output stops to terminate the command and get back to the prompt)
> openssl s_client -showcerts -connect s3.amazonaws.com:443
Following is the expected output of those two commands.
From appcenter.html5tools-software.intel.com:
0 s:/C=US/ST=CA/L=Santa Clara/O=Intel Corporation/CN=appcenter.html5tools-software.intel.com
   i:/C=US/ST=CA/L=Santa Clara/O=Intel Corporation/CN=Intel External Issuing CA 6A
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
1 s:/C=US/ST=CA/L=Santa Clara/O=Intel Corporation/CN=Intel External Issuing CA 6A
   i:/C=GB/ST=Greater Manchester/L=Salford/O=COMODO CA Limited/CN=COMODO RSA Certification Authority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2 s:/C=GB/ST=Greater Manchester/L=Salford/O=COMODO CA Limited/CN=COMODO RSA Certification Authority
   i:/C=SE/O=AddTrust AB/OU=AddTrust External TTP Network/CN=AddTrust External CA Root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Server certificate
subject=/C=US/ST=CA/L=Santa Clara/O=Intel Corporation/CN=appcenter.html5tools-software.intel.com
issuer=/C=US/ST=CA/L=Santa Clara/O=Intel Corporation/CN=Intel External Issuing CA 6A
From s3.amazonaws.com:
0 s:/C=US/ST=Washington/L=Seattle/O=Amazon.com Inc./CN=s3.amazonaws.com
   i:/C=US/O=DigiCert Inc/OU=www.digicert.com/CN=DigiCert Baltimore CA-2 G2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1 s:/C=US/O=DigiCert Inc/OU=www.digicert.com/CN=DigiCert Baltimore CA-2 G2
   i:/C=IE/O=Baltimore/OU=CyberTrust/CN=Baltimore CyberTrust Root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Giovanni_B_1
Hello, I've just updated to 3491 version and I still have the the same error:
ERROR (-9) from "client:upload-manager": Error in uploading project files: : Error in uploading project files: : Error in uploading project files: : tunneling socket could not be established, cause=Parse Error Error at new ComponentError (C:\Users\d6371\AppData\Local\Intel\XDK\xdk\core-modules\public\component-error.js:17:1122) at makeError (file:///C:/Users/d6371/AppData/Local/Intel/XDK/xdk/components/client/upload-manager/upload-manager.js:17:170) at getComponentError (file:///C:/Users/d6371/AppData/Local/Intel/XDK/xdk/components/client/upload-manager/upload-manager.js:17:265) at file:///C:/Users/d6371/AppData/Local/Intel/XDK/xdk/components/client/upload-manager/upload-manager.js:17:12970 at _rejected (C:\Users\d6371\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:844:24) at C:\Users\d6371\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:870:30 at Promise.when (C:\Users\d6371\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:1122:31) at Promise.promise.promiseDispatch (C:\Users\d6371\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:788:41) at C:\Users\d6371\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:604:44 at runSingle (C:\Users\d6371\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:137:13)
Have you got any news about it?
Thank you
PaulF_IntelCorp
Giovanni -- have you tried the workarounds suggested in this forum thread?
Jane_S_
How can I uninstall 3491 and go back to a previous version? My code, which depends on plugins, is no longer working.
PaulF_IntelCorp
Jane -- see the known issues in the release notes, there is a link related to Construct2 that will help you find it. If you are using the old Intel XDK plugins you should update your code to quit using those APIs, those plugins have not been updated for well over a year and are now obsolete. All the core Cordova plugins are present in the Simulate tab and the plugin manager continues to work as it did in previous versions. I recommend you use the Debug tab if you need to debug apps with third-party plugins.
Ricardo_R_
I have also this problem: ERROR (-7) from "client:upload-manager": Error in zipping package asset files: : File not found: D:, with Intel XDK 3491. Somebody solved this problem?
Thank you!
PaulF_IntelCorp
Please download the just released hotfix -- 3522 from http://xdk.intel.com
