Hi,all!
I use the xdk (version 3357) caught so many problems today and not solved.! I try it all the day and have no ways !
1. I use a proxy to connect my network. it build faild with something like
ERROR (-9) from "client:upload-manager": Error in uploading project files: : Error in uploading project files: : Error in uploading project files: : unable to verify the first certificate Error at new ComponentError (F:\software\XDK\xdk\core-modules\public\component-error.js:17:1122) at makeError (file:///F:/software/XDK/xdk/components/client/upload-manager/upload-manager.js:17:170) at getComponentError (file:///F:/software/XDK/xdk/components/client/upload-manager/upload-manager.js:17:265) at file:///F:/software/XDK/xdk/components/client/upload-manager/upload-manager.js:17:11448 at _rejected (F:\software\XDK\xdk\node_modules\q\q.js:844:24) at F:\software\XDK\xdk\node_modules\q\q.js:870:30 at Promise.when (F:\software\XDK\xdk\node_modules\q\q.js:1122:31) at Promise.promise.promiseDispatch
2 when i turn off the proxy and restart xdk and build it to android ,it will run all day with uploading project files,i have wait more than 3-4 hours and also try it again and again,my project is small!
image:
- Tags:
- HTML5
- Intel® XDK
This seems to be related to an issue with your installer. Can you uninstall Intel XDK, reboot your machine and reinstall Intel XDK? This should address your issue.
Hello, I have a similar problem with XDK 3400.
The error is "unable to upload the project files" and inside log: "tunneling socket could not be established".
Fortunately I had a copy of version 3240 installed: everything works fine with the older version.
Iele - did you try reinstalling 3357? Or try upgrading to 3400?
Giovanni - I am glad you could continue your work with a previous version. Since 3400 has been out for a week and we haven't heard of others having this issue with 3400, I would guess that there was a problem with installation, and a retry might fix it.
Avi -- does it work if you try from your home network?
We've alerted engineering to see if we can figure out what's behind this issue.
Regarding the upload problems, engineering suggests trying the following:
- in the root of your project directory create a file name intelxdk.upload.request.txt
- inside that file add a single line with the number 120
- exit and restart the XDK
The presence of that file, in the root of your app’s project directory, causes version 3400 of the XDK to use an alternate upload method for all files that are less than 120MB in size. I’ve attached an example of such a file. It should be located in the same place where you find the various intelxdk.config.*.xml files inside your project directory (at the root of your project directory).
Please let us know if this fixes this upload problem.
I placed that file into my directory and I am still getting the same error.
Rob -- engineering suggests doing the following, in order to get more detailed information from node-webkit, which is what the XDK actually runs on top of (it has a private copy of nw as part of it's installation):
1. Go into your users (theirlogin) AppData\Local\Intel\Xdk\bin folder
2. to get there (in Windows) type %localappdata% in the filepath box
3. Edit the file named xdk.cmd (make a copy first)
4. Find and replace these lines in xdk.cmd
> call :format "%pwd%..xdk" %%xd
> "%nw%" "%xd%"
with
> "%nw%" "%xd%" --enable-logging --v=1
That is add space dash-dash-enable-dash-logging space dash-dash-vee-equals-one
5. Run xdk.cmd to launch the XDK
6. Get to the point where clicking the build button fails
7. Copy the debug.log file and send it to us PRIVATELY (it may contain sensitive info)
8. Revert back to the original xdk.cmd
I'll send you a private message that you can reply to in order to send back the resulting log file. Note that this is a four day holiday weekend, so there will not be any action taken on this until we return to work on Wednesday of next week.
Also, another request is to use openssl to see the certificate chains being returned by the server. This will help to understand if there is a network interception happening, which might be interfering with the certificate authentication process. If you do not have openssl installed on your system you'll need to download and install it to perform the following test.
From a command prompt:
> openssl s_client -showcerts -connect appcenter.html5tools-software.intel.com:443
(type ^C after the output stops to terminate the command and get back to the prompt)
> openssl s_client -showcerts -connect s3.amazonaws.com:443
Following is the expected output of those two commands.
From appcenter.html5tools-software.intel.com:
0 s:/C=US/ST=CA/L=Santa Clara/O=Intel Corporation/CN=appcenter.html5tools-software.intel.com i:/C=US/ST=CA/L=Santa Clara/O=Intel Corporation/CN=Intel External Issuing CA 6A -----BEGIN CERTIFICATE----- MIIG3zCCBMegAwIBAgITFwAAADZM+voloQxkGgAAAAAANjANBgkqhkiG9w0BAQsF ADBzMQswCQYDVQQGEwJVUzELMAkGA1UECBMCQ0ExFDASBgNVBAcTC1NhbnRhIENs YXJhMRowGAYDVQQKExFJbnRlbCBDb3Jwb3JhdGlvbjElMCMGA1UEAxMcSW50ZWwg RXh0ZXJuYWwgSXNzdWluZyBDQSA2QTAeFw0xNTEyMTUwMTU5MjlaFw0xNzEyMDQw MTU5MjlaMH4xCzAJBgNVBAYTAlVTMQswCQYDVQQIEwJDQTEUMBIGA1UEBxMLU2Fu dGEgQ2xhcmExGjAYBgNVBAoTEUludGVsIENvcnBvcmF0aW9uMTAwLgYDVQQDEydh cHBjZW50ZXIuaHRtbDV0b29scy1zb2Z0d2FyZS5pbnRlbC5jb20wggEiMA0GCSqG SIb3DQEBAQUAA4IBDwAwggEKAoIBAQDNT26uwmvp5ZM46TMSYDLs1HxK67bNOpUX lB2JACdQlM3TaCHl/xq57HCpOZvSSsYdbdd4Qgh7dnED3Vzvd/7ZFU0eJZ1xNctW Wreu3ONEFGHbERtQ0IvopDXJtyNW2F1mdDMHzTBvp/FwfWYpsDgAFAU8rSvRMRgh 01fch3NWdJUtjKLJWAvAXu3e6ZtFLL178p/fu/wdqG5CXb68GsgwnMKLHHv9m8mM FVASXFECRAO+v1BFgf4sXrlDBQAigx1R060bUrrimrzeEFrrudMCC1Qflqt197yU YU7tXXvHhD52GvhXv9RO+LHEiNop0F6OhzQWrvQ8IHaXhYYQevYFAgMBAAGjggJf MIICWzALBgNVHQ8EBAMCBaAwHQYDVR0lBBYwFAYIKwYBBQUHAwIGCCsGAQUFBwMB MIIBCwYDVR0RBIIBAjCB/4IdaHRtbDV0b29scy1zb2Z0d2FyZS5pbnRlbC5jb22C J2FwcGNlbnRlci5odG1sNXRvb2xzLXNvZnR3YXJlLmludGVsLmNvbYImc2Vydmlj ZXMuaHRtbDV0b29scy1zb2Z0d2FyZS5pbnRlbC5jb22CL2FwcGNlbnRlci1zdGFn aW5nLmh0bWw1dG9vbHMtc29mdHdhcmUuaW50ZWwuY29tgi9hcHBjZW50ZXItcHJl cHJvZC5odG1sNXRvb2xzLXNvZnR3YXJlLmludGVsLmNvbYIrYXBwY2VudGVyLWRl di5odG1sNXRvb2xzLXNvZnR3YXJlLmludGVsLmNvbTAdBgNVHQ4EFgQUz2dCnbAt LaeRKQSPQSID7jGyN1MwHwYDVR0jBBgwFoAUJBhg8FZ8kR5JFyaxONIn9EYxg2Mw NwYDVR0fBDAwLjAsoCqgKIYmaHR0cDovL3BraS5pbnRlbC5jb20vY3JsL0ludGVs Q0E2QS5jcmwwZgYIKwYBBQUHAQEEWjBYMDIGCCsGAQUFBzAChiZodHRwOi8vcGtp LmludGVsLmNvbS9jcnQvSW50ZWxDQTZBLmNydDAiBggrBgEFBQcwAYYWaHR0cDov L09DU1AuaW50ZWwuY29tLzA9BgkrBgEEAYI3FQcEMDAuBiYrBgEEAYI3FQiGw4x1 hJnlUYP9gSiFjp9TgpHACWeF2r83hZqMUAIBZAIBGTANBgkqhkiG9w0BAQsFAAOC AgEA7CQgcgwu+DTZQODvE0juYZDqLW8xVBAJdNCxnmONC2WVgRgBoOn6lN/re0fJ oUA3a7iWPcsWzZHW/ZHgJTCbTd0X5tVtd0rjshrQ+eUj3MOPZ7Jo9eUx3WVXimE+ obCkH2ErEdNKCMbggC7u/8jj8cxOEUq0LG4Z1KBiXGCUgudc4AN6RpmlQTYelHSr d3t3d+dVeEO2n4QMfXhdoD9MU9/UF34sy4FdOlThoPEAQdSCRs6l98pDf/E/Yv4z KUOQPRUf1aQufOwKZl7/P0lhZ8QPwwhfTTFAv03nhaf9K7YPnYh2SMPG3prh89fw 8XS6v26Y/8SbU1QWsDManE38o3ciSR2GBVT7YYCjIWpRhN0SX9cbFbmPYQ4bvsn4 7D17Bo63+Net/WJCuKtWZER316ip+m2IZxGpgChVn4yH0jZVZBISoZqX6v5QDLlM rGf/HEh+qoDUMKldQtbhj+e0TCGvPV09esliv5q2sGQBc1ycVL9GZqMia3kV4+wy QHGtj20MDnc7RT+tkWW+9VKoN8uNRqJBub+4HUA6pbxK2fDMo6XXFjpDdD0W7VXR GiRz1/li+D5R7uS5G+PbsMNUKRK5qMcxRHBxYc4eaIjWJId05ToX1vhZJYrDK7Uf 9jN5n7RInLvr/n3vgtfTZIMS+5c0va42d49UogPVf/FomL4= -----END CERTIFICATE----- 1 s:/C=US/ST=CA/L=Santa Clara/O=Intel Corporation/CN=Intel External Issuing CA 6A i:/C=GB/ST=Greater Manchester/L=Salford/O=COMODO CA Limited/CN=COMODO RSA Certification Authority -----BEGIN CERTIFICATE----- MIIPHzCCDQegAwIBAgIQCVqIR/nTSpw48+BdOzyMHDANBgkqhkiG9w0BAQwFADCB hTELMAkGA1UEBhMCR0IxGzAZBgNVBAgTEkdyZWF0ZXIgTWFuY2hlc3RlcjEQMA4G A1UEBxMHU2FsZm9yZDEaMBgGA1UEChMRQ09NT0RPIENBIExpbWl0ZWQxKzApBgNV BAMTIkNPTU9ETyBSU0EgQ2VydGlmaWNhdGlvbiBBdXRob3JpdHkwHhcNMTUxMDI2 MDAwMDAwWhcNMjEwNjE3MjM1OTU5WjBzMQswCQYDVQQGEwJVUzELMAkGA1UECBMC Q0ExFDASBgNVBAcTC1NhbnRhIENsYXJhMRowGAYDVQQKExFJbnRlbCBDb3Jwb3Jh dGlvbjElMCMGA1UEAxMcSW50ZWwgRXh0ZXJuYWwgSXNzdWluZyBDQSA2QTCCAiIw DQYJKoZIhvcNAQEBBQADggIPADCCAgoCggIBAPXjZVXWxm8o3ma8h/A/MkqOYvUw 2VY35HBuP/S+oxm7RTfFgQUa7uUrlwLDDpyShkYyYeC1oFB41BxOn+4JGO/O5zBU c3rZhRpXLutNI6B4zu9ae4xcZCMkn8hhzX9NWdOvi0PuTqTHFZFCXKUa8rd7np6O LbnjtwXV0OFGMjJZrcnNWtMlDifecK+6GxlIskxPM1Rh9eDVBUBYAUhCrg/Oiove BfLthqRDjxVFcH8nWB6/mxA9WBFpNz7sXXFIToGXcbWFeKYigrNw5/0YfncCMKS5 wjffIyrwNL1/LOY6GJtkY3YuCcP0yb0amxfWk6VA6kumiYZ6pNOoNa/NcaESdeYq Ql43feVGrtjWcN7gnF2oU2Ue3TSlHkyl8eh08CB4tMC21CbXBTP4YKbuPnEnAN2k Y65fLv+Z7D016szl3CBOPrvOy3tw/4tY9XMa1daL25oU6RC/K6x5Ho9vh+fz/PsO 9WdWcnA8eQi4TfALLCZt2BSYtlDYiBmA64hYDAKl6xd/v+ie7zLyo1v9YvHxLN74 UqZvC1IbDRQJ8JVGCvSMNIFAtmz6BGGgqNHpKGeIoWB37DYoqdz2m+3w2ZyQzqqA t5JBehSnKisYb+/llHQR5xDavFODyPtC33jiYWuwSJlb6P3WZg02FWLuyvJUolnW hYqgQRIMzVVAlerXAgMBAAGjggmaMIIJljAfBgNVHSMEGDAWgBS7r34CPfqm8TyE jq3uOJjs2TIy1DAdBgNVHQ4EFgQUJBhg8FZ8kR5JFyaxONIn9EYxg2MwDgYDVR0P AQH/BAQDAgGGMBIGA1UdEwEB/wQIMAYBAf8CAQAwKAYDVR0lBCEwHwYIKwYBBQUH AwEGCCsGAQUFBwMCBgkrBgEEAYI3FQUwIgYDVR0gBBswGTANBgsqhkiG+E0BBQFp ATAIBgZngQwBAgIwTAYDVR0fBEUwQzBBoD+gPYY7aHR0cDovL2NybC5jb21vZG9j YS5jb20vQ09NT0RPUlNBQ2VydGlmaWNhdGlvbkF1dGhvcml0eS5jcmwwcQYIKwYB BQUHAQEEZTBjMDsGCCsGAQUFBzAChi9odHRwOi8vY3J0LmNvbW9kb2NhLmNvbS9D T01PRE9SU0FBZGRUcnVzdENBLmNydDAkBggrBgEFBQcwAYYYaHR0cDovL29jc3Au Y29tb2RvY2EuY29tMIIIHwYDVR0eBIIIFjCCCBKgggfcMAiCBjAxLm9yZzAMggph Y3BpY2Eub3JnMA2CC2Fkc2Rjc3AuY29tMAuCCWFwcHVwLmNvbTAVghNhc2tpbnRl bHN1cHBvcnQuY29tMA6CDGNpbGtwbHVzLm9yZzAQgg5jbGVhcmxpbnV4Lm9yZzAT ghFjbG91ZGluc2lnaHRzLmNvbTAOggxjbG91ZG5wby5vcmcwF4IVY2x1c3RlcmNv bm5lY3Rpb24uY29tMBSCEmNvZmx1ZW50ZGVzaWduLmNvbTAXghVjcm9zc3dhbGst cHJvamVjdC5vcmcwE4IRZWRhY2FkdG9vbGtpdC5vcmcwE4IRZXhhc2NhbGUtdGVj aC5jb20wDYILaWJicHJvZi5jb20wC4IJaWhjbXMubmV0MA6CDGluYy1uZXN0Lm5l dDAWghRpbmRpYWVkdXNlcnZpY2VzLmNvbTAQgg5pbmZyYS1ob3N0LmNvbTARgg9p bnNpZGVmaWxtcy5jb20wE4IRaW50ZWxhbGxpYW5jZS5jb20wFIISaW50ZWxhcGFj c3RvcmUuY29tMBmCF2ludGVsYmV0dGVydG9nZXRoZXIuY29tMAqCCGludGVsLmNo MBSCEmludGVsY2hhbGxlbmdlLmNvbTATghFpbnRlbGNoYWxsZW5nZS5ldTATghFp bnRlbGNoYWxsZW5nZS5tZTATghFpbnRlbGNsb3Vkc3NvLmNvbTAKgghpbnRlbC5j bjANggtpbnRlbC5jby5hZTANggtpbnRlbC5jby5pZDANggtpbnRlbC5jby5rcjAL gglpbnRlbC5jb20wDoIMaW50ZWwuY29tLmF1MA6CDGludGVsLmNvbS5jbjAOggxp bnRlbC5jb20udHIwDoIMaW50ZWwuY29tLnR3MB6CHGludGVsY29uc3VtZXJlbGVj dHJvbmljcy5jb20wDYILaW50ZWwuY28udWswDYILaW50ZWwuY28uemEwCoIIaW50 ZWwuY3owCoIIaW50ZWwuZGUwFIISaW50ZWxlbnNldmVudHMuY29tMBaCFGludGVs ZmVsbG93c2hpcHMuY29tMBOCEWludGVsZmxleHBsdXMuY29tMAqCCGludGVsLmZy MBSCEmludGVsZnJlZXByZXNzLmNvbTAWghRpbnRlbGh5YnJpZGNsb3VkLmNvbTAK gghpbnRlbC5pbjAKgghpbnRlbC5pdDAKgghpbnRlbC5qcDAKgghpbnRlbC5rejAP gg1pbnRlbG1lZGlhLnR2MAqCCGludGVsLm15MAuCCWludGVsLm5ldDAKgghpbnRl bC5ubDALgglpbnRlbC5vcmcwCoIIaW50ZWwucGwwFIISaW50ZWxwb3J0Zm9saW8u Y29tMA6CDGludGVsLXJhLmNvbTAUghJpbnRlbC1yZXNlYXJjaC5uZXQwFIISaW50 ZWxybWFzdXJ2ZXkuY29tMAqCCGludGVsLnJvMAqCCGludGVsLnJ1MAqCCGludGVs LnNhMBeCFWludGVsc2FsZXNhZHZpc29yLmNvbTATghFpbnRlbHNlY3VyaXR5LmNv bTAYghZpbnRlbHNtYWxsYnVzaW5lc3MuY29tMB2CG2ludGVsdGVjaG5vbG9neXBy b3ZpZGVyLmNvbTAKgghpbnRlbC51YTAKgghpbnRlbC52bjALgglpb3Rjcy5jb20w DIIKbWNhZmVlLmNvbTANggtteWJhc2lzLmNvbTARgg9teWludGVsZWRnZS5jb20w EYIPbXktbGFwdG9wLmNvLnVrMBSCEm15bWVkaWFsaWJyYXJ5Lm5ldDARgg9vZG1z aG93Y2FzZS5jb20wC4IJb2Zvbm8ub3JnMA+CDW9wZW5tcHJ0bC5vcmcwEoIQb3Jp Z2luLWFwcHVwLmNvbTAeghxvcmlnaW4taW50ZWdyYXRpb24tYXBwdXAuY29tMA2C C290Y2NoYXQub3JnMA6CDG90Y3NoYXJlLm9yZzARgg9wYXNzd29yZGRheS5vcmcw CIIGcGMuY29tMBSCEnBjdGhlZnRkZWZlbmNlLmNvbTAUghJwY3RoZWZ0ZGVmZW5z ZS5jb20wEYIPcGljc250aGluZ3MuY29tMBOCEXBvY2tldGF2YXRhcnMuY29tMBSC EnBvd2VyZWRieWludGVsLmNvbTAOggxwdmF0cmlhbC5uZXQwGYIXcmVkZWZpbmV5 b3VybmV0d29yay5jb20wD4INcmV0YWlsLWlhLmNvbTAUghJzZXJ2ZXItaW5zaWdo dC5jb20wFIISc2ltcGxlZmlybXdhcmUub3JnMBSCEnNtYXJ0cGVyaW1ldGVyLmNv bTAUghJzb2xldHRhcHJvamVjdC5vcmcwE4IRc3luY2V2b2x1dGlvbi5vcmcwE4IR dGhlaW50ZWxzdG9yZS5jb20wHYIbdGhyZWFkaW5nYnVpbGRpbmdibG9ja3Mub3Jn MBuCGXRodW5kZXJib2x0dGVjaG5vbG9neS5uZXQwD4INdGlhbm9jb3JlLm9yZzAN ggt0cnVla2V5LmNvbTAPgg13aGFtY2xvdWQuY29tMAuCCXlhcG1lLmNvbTBQpE4w TDELMAkGA1UEBhMCVVMxCzAJBgNVBAgTAkNBMRQwEgYDVQQHEwtTYW50YSBDbGFy YTEaMBgGA1UEChMRSW50ZWwgQ29ycG9yYXRpb26hMDAKhwgAAAAAAAAAADAihyAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADANBgkqhkiG9w0BAQwFAAOC AgEAbJ1S6p3VOsCxYoNeXvpuYJLZ6IN5owgYqHYnQJRKquntr8GfKAFbvS9PvcL0 LZZOQ7qF0aIMJS5ClruLLJgVoZGrklVHuftT5PQJ+znd1PrFRTjQY9msaFfv8IJ0 JmuPK2qBicJc0HLdSi2E93LC4YFzs3fZieEv/HT5oGq/F3p3Epv7obUn6BY9lRzy 8SwA0N/LPbYVTeU51rljKM/YbVlqvkx60ajfIPrFjyThYIPGmdIU0W/y6tX0GkyE 8G0J5NI77bdj++3sI03o+aKefsBAWdTwxu+VSzAAox+KX8UrMbN+Cl7r7F+n3/YV 66xcIg6GTIB6FmGmsKhkod19z6xiw2zURd/CQgo3iYapITJHMwxkYAtzebaoXWVU y9j7JkCJ+q4WwKm1TVvOJHhUVS/+Vj3PsomFa8xcecQ7cK2HU0R3vAJbFFgS2KQy 8Yn3P1RYj+CwoAfhU5ioMnZ7OZIQVoNtFmzKTdBI5LTkc8svJxJ9WNFMTmoM5clm +yojqkqQ0MKfE7eUlwFwmGH3hlFnB1VCR9UOylW3csQtbV29BxKv9gX5e2hQ+gd/ XJO9Hpo1iUwwE1CYieueOq1iXo7FpoVbldNHe9LSBHpS7QySZpXBxzavVwNmLi7r wAvmrMLslMFElMTQgNTPHnwGKFvf4zlMDpjafENit4AzTvY= -----END CERTIFICATE----- 2 s:/C=GB/ST=Greater Manchester/L=Salford/O=COMODO CA Limited/CN=COMODO RSA Certification Authority i:/C=SE/O=AddTrust AB/OU=AddTrust External TTP Network/CN=AddTrust External CA Root -----BEGIN CERTIFICATE----- MIIFdDCCBFygAwIBAgIQJ2buVutJ846r13Ci/ITeIjANBgkqhkiG9w0BAQwFADBv MQswCQYDVQQGEwJTRTEUMBIGA1UEChMLQWRkVHJ1c3QgQUIxJjAkBgNVBAsTHUFk ZFRydXN0IEV4dGVybmFsIFRUUCBOZXR3b3JrMSIwIAYDVQQDExlBZGRUcnVzdCBF eHRlcm5hbCBDQSBSb290MB4XDTAwMDUzMDEwNDgzOFoXDTIwMDUzMDEwNDgzOFow gYUxCzAJBgNVBAYTAkdCMRswGQYDVQQIExJHcmVhdGVyIE1hbmNoZXN0ZXIxEDAO BgNVBAcTB1NhbGZvcmQxGjAYBgNVBAoTEUNPTU9ETyBDQSBMaW1pdGVkMSswKQYD VQQDEyJDT01PRE8gUlNBIENlcnRpZmljYXRpb24gQXV0aG9yaXR5MIICIjANBgkq hkiG9w0BAQEFAAOCAg8AMIICCgKCAgEAkehUktIKVrGsDSTdxc9EZ3SZKzejfSNw AHG8U9/E+ioSj0t/EFa9n3Byt2F/yUsPF6c947AEYe7/EZfH9IY+Cvo+XPmT5jR6 2RRr55yzhaCCenavcZDX7P0N+pxs+t+wgvQUfvm+xKYvT3+Zf7X8Z0NyvQwA1onr ayzT7Y+YHBSrfuXjbvzYqOSSJNpDa2K4Vf3qwbxstovzDo2a5JtsaZn4eEgwRdWt 4Q08RWD8MpZRJ7xnw8outmvqRsfHIKCxH2XeSAi6pE6p8oNGN4Tr6MyBSENnTnIq m1y9TBsoilwie7SrmNnu4FGDwwlGTm0+mfqVF9p8M1dBPI1R7Qu2XK8sYxrfV8g/ vOldxJuvRZnio1oktLqpVj3Pb6r/SVi+8Kj/9Lit6Tf7urj0Czr56ENCHonYhMsT 8dm74YlguIwoVqwUHZwK53Hrzw7dPamWoUi9PPevtQ0iTMARgexWO/bTouJbt7IE IlKVgJNp6I5MZfGRAy1wdALqi2cVKWlSArvX31BqVUa/oKMoYX9w0MOiqiwhqkfO KJwGRXa/ghgntNWutMtQ5mv0TIZxMOmm3xaG4Nj/QN370EKIf6MzOi5cHkERgWPO GHFrK+ymircxXDpqR+DDeVnWIBqv8mqYqnK8V0rSS527EPywTEHl7R09XiidnMy/ s1Hap0flhFMCAwEAAaOB9DCB8TAfBgNVHSMEGDAWgBStvZh6NLQm9/rEJlTvA73g JMtUGjAdBgNVHQ4EFgQUu69+Aj36pvE8hI6t7jiY7NkyMtQwDgYDVR0PAQH/BAQD AgGGMA8GA1UdEwEB/wQFMAMBAf8wEQYDVR0gBAowCDAGBgRVHSAAMEQGA1UdHwQ9 MDswOaA3oDWGM2h0dHA6Ly9jcmwudXNlcnRydXN0LmNvbS9BZGRUcnVzdEV4dGVy bmFsQ0FSb290LmNybDA1BggrBgEFBQcBAQQpMCcwJQYIKwYBBQUHMAGGGWh0dHA6 Ly9vY3NwLnVzZXJ0cnVzdC5jb20wDQYJKoZIhvcNAQEMBQADggEBAGS/g/FfmoXQ zbihKVcN6Fr30ek+8nYEbvFScLsePP9NDXRqzIGCJdPDoCpdTPW6i6FtxFQJdcfj Jw5dhHk3QBN39bSsHNA7qxcS1u80GH4r6XnTq1dFDK8o+tDb5VCViLvfhVdpfZLY Uspzgb8c8+a4bmYRBbMelC1/kZWSWfFMzqORcUx8Rww7Cxn2obFshj5cqsQugsv5 B5a6SE2Q8pTIqXOi6wZ7I53eovNNVZ96YUWYGGjHXkBrI/V5eu+MtWuLt29G9Hvx PUsE2JOAWVrgQSQdso8VYFhH2+9uRv0V9dlfmrPb2LjkQLPNlzmuhbsdjrzch5vR pu/xO28QOG8= -----END CERTIFICATE----- --- Server certificate subject=/C=US/ST=CA/L=Santa Clara/O=Intel Corporation/CN=appcenter.html5tools-software.intel.com issuer=/C=US/ST=CA/L=Santa Clara/O=Intel Corporation/CN=Intel External Issuing CA 6A
From s3.amazonaws.com:
0 s:/C=US/ST=Washington/L=Seattle/O=Amazon.com Inc./CN=s3.amazonaws.com i:/C=US/O=DigiCert Inc/OU=www.digicert.com/CN=DigiCert Baltimore CA-2 G2 -----BEGIN CERTIFICATE----- MIIFRDCCBCygAwIBAgIQBW5PwbtXuqp9pLjReKAHKzANBgkqhkiG9w0BAQsFADBk MQswCQYDVQQGEwJVUzEVMBMGA1UEChMMRGlnaUNlcnQgSW5jMRkwFwYDVQQLExB3 d3cuZGlnaWNlcnQuY29tMSMwIQYDVQQDExpEaWdpQ2VydCBCYWx0aW1vcmUgQ0Et MiBHMjAeFw0xNTEyMDgxMjA1MDhaFw0xNjEwMTgxMjAwMDBaMGkxCzAJBgNVBAYT AlVTMRMwEQYDVQQIEwpXYXNoaW5ndG9uMRAwDgYDVQQHEwdTZWF0dGxlMRgwFgYD VQQKEw9BbWF6b24uY29tIEluYy4xGTAXBgNVBAMTEHMzLmFtYXpvbmF3cy5jb20w ggEiMA0GCSqGSIb3DQEBAQUAA4IBDwAwggEKAoIBAQCCi6DtQTH00lA3gx646D/Z 7ggKF32LzmbBD9bkQ9r9kv+9frLLlkMj++/LK1t2Pa86sGiKyX0LRKgg8/GUSaWf ZaOmZLy0q6G6mA+221g9jzwGoY3/X7p909hVZKRLWaHQI0b4YKxgp3LQEiRCVGOB mAwAua3s1eb0IZuOpw+RBXPJIMJDL0l7saliOOZMXTLgdBS26iBX65ty+mIbGO9q vpIEOPy2bzwNhRGzPYpFQGrsgINzt+VkWW27d2Q52i8kDNGFMC3DAnDgH7tIRABk WzApOygTCs9mSYVar2itrbTF8FncB9aeiErIMQAisDuHAogM6EXGUJHc+xn/H6kn AgMBAAGjggHrMIIB5zAfBgNVHSMEGDAWgBTAErIodGhGZ+lwJXQaAEVbBn1cRDAd BgNVHQ4EFgQUsqv7Hfrf/AIOyQcqgCxetxyYGC0wGwYDVR0RBBQwEoIQczMuYW1h em9uYXdzLmNvbTAOBgNVHQ8BAf8EBAMCBaAwHQYDVR0lBBYwFAYIKwYBBQUHAwEG CCsGAQUFBwMCMIGBBgNVHR8EejB4MDqgOKA2hjRodHRwOi8vY3JsMy5kaWdpY2Vy dC5jb20vRGlnaUNlcnRCYWx0aW1vcmVDQS0yRzIuY3JsMDqgOKA2hjRodHRwOi8v Y3JsNC5kaWdpY2VydC5jb20vRGlnaUNlcnRCYWx0aW1vcmVDQS0yRzIuY3JsMEwG A1UdIARFMEMwNwYJYIZIAYb9bAEBMCowKAYIKwYBBQUHAgEWHGh0dHBzOi8vd3d3 LmRpZ2ljZXJ0LmNvbS9DUFMwCAYGZ4EMAQICMHkGCCsGAQUFBwEBBG0wazAkBggr BgEFBQcwAYYYaHR0cDovL29jc3AuZGlnaWNlcnQuY29tMEMGCCsGAQUFBzAChjdo dHRwOi8vY2FjZXJ0cy5kaWdpY2VydC5jb20vRGlnaUNlcnRCYWx0aW1vcmVDQS0y RzIuY3J0MAwGA1UdEwEB/wQCMAAwDQYJKoZIhvcNAQELBQADggEBAIohm7PES6xk 8eaT/+SwlY191VWC9M9ZKEkUbopL4bvfT17pGmBnOWJa4xqb3g6kPh6SYfojtRkg mHgniD3wkI8q6jEyEitkLFGXyiJFrJ7hvWBryvj9Tiw4VfmE6y6tB684VN2js2gn h3QWQwHMC+Qel5+Hf3rmXbbHENfrSRDVEix67ATXbVzQurXf+iEH/FPwDQ/2sJii Me9J0VhvnUWNvIvi0nxrzqqeBunHa1GjT+JT0wzWlAE/zoSiraMpJ7NWHamNb5q2 rhk3SQRnDC0nRpjAdfQ0t7aQY3aIMUlmfHADMcgbcJsQVQcxRRyXqos68my8cFx/ MJwQTEif8fo= -----END CERTIFICATE----- 1 s:/C=US/O=DigiCert Inc/OU=www.digicert.com/CN=DigiCert Baltimore CA-2 G2 i:/C=IE/O=Baltimore/OU=CyberTrust/CN=Baltimore CyberTrust Root -----BEGIN CERTIFICATE----- MIIEYzCCA0ugAwIBAgIQAYL4CY6i5ia5GjsnhB+5rzANBgkqhkiG9w0BAQsFADBa MQswCQYDVQQGEwJJRTESMBAGA1UEChMJQmFsdGltb3JlMRMwEQYDVQQLEwpDeWJl clRydXN0MSIwIAYDVQQDExlCYWx0aW1vcmUgQ3liZXJUcnVzdCBSb290MB4XDTE1 MTIwODEyMDUwN1oXDTI1MDUxMDEyMDAwMFowZDELMAkGA1UEBhMCVVMxFTATBgNV BAoTDERpZ2lDZXJ0IEluYzEZMBcGA1UECxMQd3d3LmRpZ2ljZXJ0LmNvbTEjMCEG A1UEAxMaRGlnaUNlcnQgQmFsdGltb3JlIENBLTIgRzIwggEiMA0GCSqGSIb3DQEB AQUAA4IBDwAwggEKAoIBAQC75wD+AAFz75uI8FwIdfBccHMf/7V6H40II/3HwRM/ sSEGvU3M2y24hxkx3tprDcFd0lHVsF5y1PBm1ITykRhBtQkmsgOWBGmVU/oHTz6+ hjpDK7JZtavRuvRZQHJaZ7bN5lX8CSukmLK/zKkf1L+Hj4Il/UWAqeydjPl0kM8c +GVQr834RavIL42ONh3e6onNslLZ5QnNNnEr2sbQm8b2pFtbObYfAB8ZpPvTvgzm +4/dDoDmpOdaxMAvcu6R84Nnyc3KzkqwIIH95HKvCRjnT0LsTSdCTQeg3dUNdfc2 YMwmVJihiDfwg/etKVkgz7sl4dWe5vOuwQHrtQaJ4gqPAgMBAAGjggEZMIIBFTAd BgNVHQ4EFgQUwBKyKHRoRmfpcCV0GgBFWwZ9XEQwHwYDVR0jBBgwFoAU5Z1ZMIJH WMys+ghUNoZ7OrUETfAwEgYDVR0TAQH/BAgwBgEB/wIBADAOBgNVHQ8BAf8EBAMC AYYwNAYIKwYBBQUHAQEEKDAmMCQGCCsGAQUFBzABhhhodHRwOi8vb2NzcC5kaWdp Y2VydC5jb20wOgYDVR0fBDMwMTAvoC2gK4YpaHR0cDovL2NybDMuZGlnaWNlcnQu Y29tL09tbmlyb290MjAyNS5jcmwwPQYDVR0gBDYwNDAyBgRVHSAAMCowKAYIKwYB BQUHAgEWHGh0dHBzOi8vd3d3LmRpZ2ljZXJ0LmNvbS9DUFMwDQYJKoZIhvcNAQEL BQADggEBAC/iN2bDGs+RVe4pFPpQEL6ZjeIo8XQWB2k7RDA99blJ9Wg2/rcwjang B0lCY0ZStWnGm0nyGg9Xxva3vqt1jQ2iqzPkYoVDVKtjlAyjU6DqHeSmpqyVDmV4 7DOMvpQ+2HCr6sfheM4zlbv7LFjgikCmbUHY2Nmz+S8CxRtwa+I6hXsdGLDRS5rB bxcQKegOw+FUllSlkZUIII1pLJ4vP1C0LuVXH6+kc9KhJLsNkP5FEx2noSnYZgvD 0WyzT7QrhExHkOyL4kGJE7YHRndC/bseF/r/JUuOUFfrjsxOFT+xJd1BDKCcYm1v upcHi9nzBhDFKdT3uhaQqNBU4UtJx5g= -----END CERTIFICATE-----
Hello, I've just updated to 3491 version and I still have the the same error:
ERROR (-9) from "client:upload-manager": Error in uploading project files: : Error in uploading project files: : Error in uploading project files: : tunneling socket could not be established, cause=Parse Error Error at new ComponentError (C:\Users\d6371\AppData\Local\Intel\XDK\xdk\core-modules\public\component-error.js:17:1122) at makeError (file:///C:/Users/d6371/AppData/Local/Intel/XDK/xdk/components/client/upload-manager/upload-manager.js:17:170) at getComponentError (file:///C:/Users/d6371/AppData/Local/Intel/XDK/xdk/components/client/upload-manager/upload-manager.js:17:265) at file:///C:/Users/d6371/AppData/Local/Intel/XDK/xdk/components/client/upload-manager/upload-manager.js:17:12970 at _rejected (C:\Users\d6371\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:844:24) at C:\Users\d6371\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:870:30 at Promise.when (C:\Users\d6371\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:1122:31) at Promise.promise.promiseDispatch (C:\Users\d6371\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:788:41) at C:\Users\d6371\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:604:44 at runSingle (C:\Users\d6371\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:137:13)
Have you got any news about it?
Thank you
Giovanni -- have you tried the workarounds suggested in this forum thread?
How can I uninstall 3491 and go back to a previous version? My code, which depends on plugins, is no longer working.
Jane -- see the known issues in the release notes, there is a link related to Construct2 that will help you find it. If you are using the old Intel XDK plugins you should update your code to quit using those APIs, those plugins have not been updated for well over a year and are now obsolete. All the core Cordova plugins are present in the Simulate tab and the plugin manager continues to work as it did in previous versions. I recommend you use the Debug tab if you need to debug apps with third-party plugins.
I have also this problem: ERROR (-7) from "client:upload-manager": Error in zipping package asset files: : File not found: D:, with Intel XDK 3491. Somebody solved this problem?
Thank you!
![](/skins/images/B7BA37F9CE4B52FF7CAE1FB0388839C8/responsive_peak/images/icon_anonymous_message.png)
