Is there any way to force idb to generate a new core dump file for the programmed being debugged? The new core dump should reflect the state of the file at the cursor location as I step though a file.
IIRC, IDB does not have a command to create a core file. You might need to set "ulimit -c" and send a signal to the process being debugged in order to create a core file. However, that also is terminating this process and is not what you might have asked for.
For a while now we replaced IDB by GNU* GDB which comes with our compilers (gdb-ia). GDB has a command to create core files: generate-core-file
Georg Zitzlsberger
