Software Archive
Read-only legacy content
17061 Discussions
how can i set input number from input text as variable x ?
zeroman_z_
setTimeout(function(){
intel.xdk.player.playSound(intel.xdk.webRoot + "sounds/1.wav");
}, x);
x is variable from input text box how i can do it ?
Swati_S_Intel1
Use getElementById to get the value from the input box.
zeroman_z_
sorry any example code ?>
zeroman_z_
 $(document).on("click", ".uib_w_3", function(evt)
        var x = document.getElementById("input");
        x=x*1000 ;
      setTimeout(function() { intel.xdk.player.playSound(intel.xdk.webRoot + "sounds/1.wav"); }, x);
>>>>>> not work
Swati_S_Intel1
First of all, as I mentioned in the other thread the intel.xdk.webRoot will not work. Use this code to get the webroot path.
// get the webroot
        var rootpath = window.location.href ;
        rootpath = rootpath.substring( 0, rootpath.lastIndexOf('/') ) ;
        // if it is a real iOS device the webroot is "/"
        var ua = navigator.userAgent;
        if( !window.tinyHippos && ua.match(/(ios)|(iphone)|(ipod)|(ipad)/ig) ) { // it's not an emulator and it's iOS
            rootpath = "" ;
Next, for your text input box value, you have to specify ID for the input box, like this :
<input id="settime" type="text">
and in Javascript get the value of the input box through getElementByID like this:
var x= document.getElementById("settime").value;
If you are new to HTML5 I would encourage you to learn from W3schools.com
zeroman_z_
thanks too much :)
