Hi, please advice me how to load image.
I want to load pre-recorded image and detect face.
when I use PerC SDK 2013, I can load it and get face data.
However, RealSense SDK might hide the function to load an image, don't it?
PerC SDK 2013
sts = face->ProcessImageAsync(&img1, sps.ReleaseRef(1));
PXCVideoModule class has ProcessImageAsync method.
I don't know how to get instance of PXCVideoModule.
Could you give me an advice or sample to load an image not live camera?
Here you go. Hope it will give you help.
PXCSyncPoint* sp = NULL; PXCImage* image = NULL; createImage(&image); PXCCapture::Sample* sample = new PXCCapture::Sample(); sample->color = image; do { sts = psm->QueryCaptureManager()->ReadModuleStreamsAsync(pFaceConfig->CUID, sample, &sp); }while (sts < PXC_STATUS_NO_ERROR); sp->Synchronize(); faceOutput->Update(); faceOutput->QueryFaceByIndex(0)->QueryRecognition()->RegisterUser();
Hi, David.
Thank you very much!
I tried your code.
But the process loops infinitely from LINE08 to LINE10.
LINE09 ReadModuleStreamAsync method returns PXC_STATUS_ITEM_UNAVAILABLE(-3)
Do you know why?
That means the SDK did not find the device meet the requirement. Do you have Intel 3D camera? The 3D camera is default in facial module. You need pFaceConfig->SetTrackingMode(PXCFaceConfiguration::TrackingModeType::FACE_MODE_COLOR); if you want to use 2D camera in facial module. Enjoy!
I don't have Intel 3D camera.
I'm using Surface Pro 3 with inner camera "Microsft LifeCam Front".
I did pFaceConfig->SetTrackingMode(PXCFaceConfiguration::TrackingModeType::FACE_MODE_COLOR);
the result is same.
I tried to change CUID.
sts = captureManager->ReadModuleStreamsAsync(PXCFaceModule::CUID, sample, &sp);
Then, ReadModuleStreamAsync method returns PXC_STATUS_NO_ERROR(0).
But m_output->QueryFaceByIndex(0) returns NULL
please help me.
I haven't yet solve my problem.
