Software Archive
Read-only legacy content
17060 Discussions
how to recover deleted text messages from android?
eve_e_
There are many android phone users, and losing important phone numbers or text messages from it happens unexpectedly. But if you need to recover them, you can use an android recovery app to help.
Just google it, you’ll find many answers, try Coolmuster Android SMS Recovery.
And you need to root your android phone at first, or the app can’t detect your phone successfully. And stop saving new data to your phone, or the deleted data will be covered.
Step1: Connect android phone to pc and start the problem
At first, connect your phone to computer via USB cable, then start the app on your computer. Make sure your phone has been linked to computer correctly, or this data recovery problem couldn’t detect it successfully.
Step2: Enable USB Debugging
You need to enable USB debugging on your device, then the data on your android phone will be synced to computer. And the problem will scan your device directly.And you just need to enable USB debugging for once.
Step3: Preview and Recover Messages
That’s all!
Baker__Emily
When you delete or remove text messages on Android phone, they would be first moved to the trash bin and the device will mark these files as inactive. That is to say, they still exist on your phone but are invisible and replaceable. And the system would not really erase them until you add some new files to cover them. Thus, you should stop using your phone if you wish to get back the deleted SMS or you will permanently lose them.
Restoring your lost Android messages to computer would be a safer way since you can backup them to PC at the same time. But to achieve this goal, you need to find a professional yet reliable Android SMS Recovery software as your assistant - MobiKin Doctor for Android.It could recover deleted Android files like text messages with several simple steps.
anderson__lisa
Murphy did amazing work,not only did he stay up considerably later than he should have been working on this hacking job,but he was very professional and well mannered throughout the entire job.I've hired many but am beyond impressed with Murphy work.it was a fantastic experience,i strongly recommend Murphy to complete any task you need done.task were completed on time and always willing to fix any extra problems. contact Murphy for any issues related to hacking via ( Murphy.c8990@gmail.com ') or on whats app only. (+16282037169)..
Guan__Alex
In fact, it is pretty easy to restore lost SMS from Android device as long as you have worked an effective recovery tool. As you know, you can find over hundreds of recovery programs online which have claimed that they can help retrieve lost Android messages. However, most of them are not as effective as they should be. So in order to successfully recover deleted text messages from Android mobile phone, you can't miss this Coolmuster Android Messages Recovery software.
By running this Android Messages Recovery, you are able to preview all deleted SMS messages before restoring. Thus you can selectively mark your deleted messages to recover, as this software can display the whole messages on your Android phone, those existing ones are no exception. In addition, no matter how many messages you have lost and ready to restore, this software allows you to retrieve them in a batch.
https://www.samsung-messages-backup.com/resources/recover-deleted-messages-from-android-phone.html
Petrenko__Vlad
Dr Fone is very simple bu effective tool if you want to recover deleted contacts. Read this turtorial if you lost your data on mobile - https://howtorecover.me/deleted-messages-android-dr-fone
Beckham__Billy
Actually, losing or deleting a message from your Android phone doesn't mean you have lost them forever. In some special situation, you still can get access & view these Android messages as you like. Below are the pre-conditions if you wish to view Android text messages after losing them:
1. Be sure the lost text messages will never be overwritten by new data. Generally speaking, when a message is deleted from your Android phone, that only means the space that used to store these messages are available again. So if no more data be saved here, you still have a big chance to get them back. So try and use your phone as little as possible or stop using it from now on.
2. Obviously, you can't get access and view lost Android text messages without any help. So search on the Internet and find a safe yet reliable 3rd-party program like MobiKin Doctor for Android (Windows/Mac) as your personal assistant.
3. Prepare a workable desktop or laptop PC, and USB cable.
https://www.mobikin.com/doctor-for-android/
jim__weliner11
Accidentally deleting or losing important files from your Android mobile phone can easily happen to any of us. If you want to recover deleted text messages from Android with a computer, Android Data Recovery is highly recommend to you. It supports you recover all file types: Messages, Contacts, Photos, Videos, Notes And Much More.
trump__jenny
Thanks for sharing really informative data. keep posting
Hassan__Mohammad
This is very interesting post.You need to enable USB debugging on your device, then the data on your android phone will be synced to computer. So thanks for sharing this information.
https://www.uaetechnician.com/hard-drive-data-recovery.html
Smith__Alice
An excellent program is required for the task - MobiKin Doctor for Android . This tool is easy to manage as you can recover lost or deleted contacts on Android phones through only several clicks. Furthermore, before you make the recovery, the program allows you to preview all the messages information, including name, phone number, email address, company address and so on. Hence, you can choose what you want and restore them selectively.
sgree12
Data backup and recovery is supported on every Android phone, go to Settings > Backup and Reset and check the last backup. If a backup is available, you can restore the backup and recover deleted text messages from android.
CSpot
Quite a nice information, you have shared here. Thanks it would help me a lot in future.
Hussain__Muzammil
@eve e.
Is this method still work in 2019?
Updates: This method is still working. I found the same method on some other websites
John__Walter
Thus, the solution to your problem is right here:-
1) With the help of your Android backup app, you can easily recover your data loss from your Android phone with the restore option.
2) Either, you can recover your deleted messages with the help of cloud storage option.
3) Else, another step is the most common and very useful method is Google Drive.
4) When all the above methods fails to get back your lost messages from Android phone then you can use a professional recovery tool like Android Data Recovery.
In future, if you come across any kind of data loss situation on your Android phone then using this software will help you to recover lost text messages and other data as well with ease.
rowse__darren
I have run into the same trouble like you. Luckily, I found a tool in Google that finally helped me out - Fucosoft Android Data Recovery. The softwate is easy to use and offers a free trial version. I suggest you try the free version first before upgrade to the full version. Simply connect your Android phone to a computer and let the program directly scan the device and finds you lost files, including contacts, text messages, photos, videos, WhatsApp, etc. One thing to note: do not save anything else to your Android device or turn off your internet connection before you try to recover your lost data. Or you lost data will be overwritten and no tools can help you recover it.
You can get it here: Android Data Recovery
Woo__Emma
I got to know a program called PR Android Data Recovery, which can deeply scan the Android phone and recover the deleted text messages for you.
With the trial version, you can also preview them for free before recovering. You can read this article on how to recover deleted text messages on Android to get more solutions.
hehou__dashi
Updated method in 2019 to retrieve deleted texts on Samsung
Firstly, it's the backup from where we can restore deleted text messages for free.
If no have backup, just phone inner storage or SD card from where we can restore deleted text messages, it's the last hope to get back lost text messages.
Louis__Sophia
There are several ways to retrieve deleted text messages from Android. I would simply suggest you to use Android SMS Recovery, one of the powerful recovery tool that restore deleted messages from Android phone.The tool is easy to use and restore text messafes deleted in any condition.
ahmed__zubair
there are several way using that data can be recover you just follow this link for step by step guide to recover your data. data recovery for android. You can also check this for more detail. Mobile packages
