Software Archive
Read-only legacy content
17060 Discussions
how to recover deleted text messages from android?
eve_e_
There are many android phone users, and losing important phone numbers or text messages from it happens unexpectedly. But if you need to recover them, you can use an android recovery app to help.
Just google it, you’ll find many answers, try Coolmuster Android SMS Recovery.
And you need to root your android phone at first, or the app can’t detect your phone successfully. And stop saving new data to your phone, or the deleted data will be covered.
Step1: Connect android phone to pc and start the problem
At first, connect your phone to computer via USB cable, then start the app on your computer. Make sure your phone has been linked to computer correctly, or this data recovery problem couldn’t detect it successfully.
Step2: Enable USB Debugging
You need to enable USB debugging on your device, then the data on your android phone will be synced to computer. And the problem will scan your device directly.And you just need to enable USB debugging for once.
Step3: Preview and Recover Messages
That’s all!
Quoc-Thai_L_Intel
Thanks for sharing. -Thai
Hbllmut_H_
If you did backup text messages to Google account.You can sign into your Google Account and check whether or not your messages still exist there. If not ,the best method to recover android phone messages use one app .
How to recover deleted text messages
Android messages recovery
eve_e_
Yes, an android data recovery app could recover your lost android phone text messages easily, more:
how to retrieve deleted text messages on android
lucy_l_
Thanks for sharing, yes, we can still recover lost mobile phone text messages with some data recovery app, and most of them are very easy to use. Try iPubsoft Android SMS Recovery, more: how to retrieve lost android phone text messages
Derp_K_
Haroon_K_
Hello !
an easy method is to download es file explorer and then search for .del and .nomedia extensions and files there you will find the your information
Haroon
Haroon_K_
And yes there are many other methods which can be found at
https://www.androidpit.com/how-to-recover-deleted-text-messages
Amir_K_2
Thanks for sharing the info.
Serena_C_
To get deleted text messages from android, this android recovery app may be helpful. Good luck.
Lena_F_
When you lost data from your android phone,
the first thing, check out the backup, whether you have synced the data to Gmail account, or saved on your pc.
Then, you should never add more data to your phone after data loss, cuz they can take up more space, the lost data will be overwritten.
Last thing, you can try android recovery methods, Recuva, you can also try professional data recovery programs.
Sahan_K_
oh thank u very much this was very help full
Sahan_K_
n also we are trying to make an app witch can this perfome be done by phone too
alan_s_1
Hey,
If you want to recover deleted text messages on Android phone, you need to find and run Android data recovery to scan your phone and SD card. It can find the deleted messages for you and you can preview them. Then you can recover deleted text messages from Android phone easily. Learn more about how to retrieve deleted text messages on Android phone.
Besides messages, you can also recover deleted photos, videos, call logs, contacts, Whatsapp messages, music, books and other document files from Android phone easily.
Bell_Y_
If you've accidentally deleted all your text messages – or even just a single, important message – you need to act fast. Lost messages are recoverable, but only until the portion of memory on which they were saved is over-written by an app update, file download or similar. So grab your phone and computer and learn how to recover deleted text messages on Android.
TunesBro DiskLab for Android is a top-notch system that quickly and effectively recovers all of your text messages.  You can use the program without rooting your phone, though TunesBro guarantees you'll be able to retrieve the full extent of your content if you do.
smalling123
Hello, if you want to retrieve your text messages from your Android phone, you can use Android SMS recovery program to do.
Here are some ways for you to recover all your lost text messages from Android phone.
After installing the program successfully, you need to connect your phone to PC, then mark the deleted messages to recover.
deveauwelle32_d_
It is possible to retrieve the lost data from Android phone, if you learn this way, you can get back the lost text messages on your phone.
In this way, you don't need to worry about so much time on doing thing, and the process is safe enough.
Therefore, you can get the direct guides here: recover deleted text messages on Android.
deveauwelle32_d_
In this situation, you need to choose some recovery software to help you, it is effective.
Flio_y_
In order to recover deleted text messages, you first need to stop adding new data to avoide overwritten the deleted SMS, then you should find a Android recovery tool on Google, some of them works for rooted Android only, others can directlly root your device to access the phone memory and then scan for  the deleted data, click recover to save them back on your PC. You can have a try for MobiKin Doctor for Android
https://youtu.be/mIimvRBSEpc
Krac_l_
Generally speaking, it is impossible to recover lost text without backup, if they are important and worth for the money, you can ask third party recovery tools for help, and do note that, root process is needed before recovering. Here is a useful guide: https://www.coolmuster.com/recovery/android-sms-recovery.html
McEwan__Ian
Recovering deleted text messages from Android is quite easy.
Here is a step by step guide for Android SMS Recovery.
