Software Archive
Read-only legacy content
17061 Discussions
how to use "ionic serve" in the XDK?
meiyu_l_
i want to make my app as a http server ,then invoke safari to download a mobile config file to setup APN setting.
I used ionic in UI .and find "ionic serve" can be a http server. but my problem is how to use "ionic serve" in Intel XDK?
Amrita_C_Intel
For this you need to type this command in the command prompt:
$ ionic serve
And then go to the emulate tab in the XDK and click choose project start file or URL and then you need to give your localhost
for example:
http://localhost:8000 ;
to see that on emulator
Else if you have HTML5 app without cordova you get option on the right hand side to run that on the web brwser
