Software Archive
Read-only legacy content
17060 Discussions
hpl-2.0 on 2 MIC cards
Sangamesh_B_
    I'm trying to run hpl-2.0(which is downloaded and compiled manually by me) on the Host system + 2 MIC cards. It fails with following error:
rank = 25, revents = 29, state = 1
Assertion failed in file ../../socksm.c at line 2963: (it_plfd->revents & POLLERR) == 0
internal ABORT - process 0
APPLICATION TERMINATED WITH THE EXIT STRING: Interrupt (signal 2)
The mpirun command used is:
export I_MPI_MIC=enable
/opt/ics/impi/4.1.1.036/intel64/bin/mpirun  -genv  I_MPI_FABRICS=shm:tcp -n 24 -host da-1 ./xhpl.cpu.T : -n 1 -host mic0 -env OMP_NUM_THREADS=244 /tmp/xhpl.mic.T : -n 1 -host mic1 -env OMP_NUM_THREADS=244 /tmp/xhpl.mic.T
What could be the reason for this?
Loc_N_Intel
Hi San,
Let me investigate this issue. Could you give me the link where you download hpl-2.0 and how you compile it?
Thank you much.
Loc_N_Intel
Hi San,
I ran hpl-2.1 successfully on my system with two coprocessors. I haven’t tried hpl-2.0 yet. Below are the steps I did:
  1. Get the hpl-2.1 source code from http://www.netlib.org/benchmark/hpl/hpl-2.1.tar.gz
  2. Get the make file for MIC sent by Francesca from his thread posted here
  3. Update this make file with your current Intel® compiler and Intel® MPI Library. In my case, I use Intel Composer XE 2013 SP1 Update 2 and MPI 4.1.3.
  4. Set env variables
    # source /opt/intel/composer_xe_2013_sp1.2.144/bin/compilervars.sh intel64
    # source /opt/intel/impi/4.1.3.048/bin64/mpivars.sh
  5. Build the application for MIC. The results are saved in ../hpl-2.1/bin/IntelMIC
  6. Modify the previous make file to build the application for host: change MKL lib and include path for intel64 instead of mic and remove “–mmic” in the make file.
  7. Build the application for host. The results are saved in ../hpl-2.1/bin/IntelHost
  8. Transfer the application for MIC (/bin/xhpl and file /bin/HPL.dat) to the directory /tmp in mic0 and mic1.
    # cd /opt/hpl-2.1-TEST/bin/IntelMIC
    # scp xhpl mic0:/tmp/
    # scp HPL.dat mic0:/tmp/
    # scp xhpl mic1:/tmp/
    # scp HPL.dat mic1:/tmp/
  9. Transfer all the necessary MPI libraries to mic0 and mic1.
    # scp /opt/intel/impi/4.1.3.048/mic/bin/* mic0:/bin/
    # scp /opt/intel/impi/4.1.3.048/mic/lib/* mic0:/lib64/
    # scp /opt/intel/composer_xe_2013_sp1.2.144/compiler/lib/mic/* mic0:/lib64/
    # scp /opt/intel/impi/4.1.3.048/mic/bin/* mic1:/bin/
    # scp /opt/intel/impi/4.1.3.048/mic/lib/* mic1:/lib64/
    # scp /opt/intel/composer_xe_2013_sp1.2.144/compiler/lib/mic/* mic1:/lib64/
  10. Enable MIC communication and configure MPSS peer-to-peer.
    # export I_MPI_MIC=enable
    # /sbin/sysctl -w net.ipv4.ip_forward=1
  11. Finally, I run the command you want successfully:
    # cd /opt/hpl-2.1-TEST/bin/IntelHost
    # mpirun -genv I_MPI_FABRICS=shm:tcp -n 24 -host localhost ./xhpl HPL.dat : -n 1 -host mic0 -env OMP_NUM_THREADS=244 -wdir /tmp ./xhpl : -n 1 -host mic1 -env OMP_NUM_THREADS=244 -wdir /tmp ./xhpl
Loc_N_Intel
Just tested with hpl-2.0, I would like to confirm that the above procedure also worked when testing hpl-2.0 downloaded from  http://www.netlib.org/benchmark/hpl
Thank you.
